2009 950T 1'st gear replace ? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 9Likes
post #1 of 13 (permalink) Old 08-05-2019, 12:15 PM Thread Starter
Any insight,please share.
I've come across a 950T with 11000m. , good price.
Owner claims first gear needs replacement (doesn't work).
Perhaps share difficulty of such a repair, or if it could be a clutch issue ?
Any insight on what to research before viewing (and falling in love) would be so appreciated!
It appears to be completely stock.
Thanks
Deeksvstarclassic likes this.
Jo hart is offline
post #2 of 13 (permalink) Old 08-05-2019, 12:22 PM
Deeksvstarclassic's Avatar
If it is in fact a 1st gear issue, if pieces of the gear is floating around more damage is probably to follow. I wouldn't think it is a clutch. It all depends on the knowledge of the person that said it is a "1st gear issue".
post #3 of 13 (permalink) Old 08-05-2019, 12:30 PM Thread Starter
More damage to follow may be correct . They claim it can be driven in 2nd and up , sooo where did 1st go? In amongst the other 4?
Jo hart is offline
post #4 of 13 (permalink) Old 08-05-2019, 12:34 PM
where did it go
and why did it go there?
there are no transmission issues on these bikes - either a rare defective part was installed, or someone did something bad to the transmission
post #5 of 13 (permalink) Old 08-05-2019, 12:35 PM
My logical guess would be in pieces unfortunately. My guess is a piece of the gear is broken.
bevo1981 likes this.
post #6 of 13 (permalink) Old 08-05-2019, 12:45 PM Thread Starter
If it was driven that way , one could expect further engine damage ? To the crank shaft ect.? Its all in the same bath of oil more or less ?
Jo hart is offline
post #7 of 13 (permalink) Old 08-05-2019, 12:47 PM
It is possible that it fell into a corner never to be heard from again but i wouldn't bet on it.
post #8 of 13 (permalink) Old 08-05-2019, 12:55 PM Thread Starter
Thank you, guys , you are rock solid ! I'm gonna take my 650 for a spin and count some blessings !!
KCW and Deeksvstarclassic like this.
Jo hart is offline
post #9 of 13 (permalink) Old 08-05-2019, 05:33 PM
2lanerider's Avatar
It is possible the linkage needs adjustment. Maybe not likely, but possible? Maybe?
I would think if broken there would be some (awful) sounds associated with it. Does it "click" into 1st but not drive the rear wheel? Or not click at all when you try to shift to 1st?
You're never really lost on a bike. You're just riding somewhere you haven't ridden before.
2lanerider is offline
post #10 of 13 (permalink) Old 08-05-2019, 08:41 PM Thread Starter
Ok , from what I've learned , it does engage into 1st (and drives) with a grinding because of missing tooth. The seller claims to have removed the piece by removing a cover and a using a magnet. Also , the heel-toe shifter has damage.
Jo hart is offline
