'05 Classic Wont Start!!! - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 8 (permalink) Old 04-12-2010, 09:14 PM Thread Starter
Hello all. I just bought my '05 V Star 1100 classic last week. It only has 4,000 miles on it and I cant get it to start. It ran fine when I picked it up. It quit on me while riding and I thought it was out of gas. So today, thinking it had bad gas in it, I put fresh gas in it. It will crank over but will not run. Any ideas????? BTW- it has a brand new battery in it, and yes I have checked the gas valve.....
grey stray is offline
post #2 of 8 (permalink) Old 04-12-2010, 10:20 PM
My next step is to check for a spark.
Philo is offline
post #3 of 8 (permalink) Old 04-12-2010, 10:28 PM
Bad gas
If you did have bad gas and pulled dirt, water, or gum into the carbs just adding gas won't do it. You will need to determin if you are getting gas to the carbs. Maybe pull a line loose. Check if you have spark first then proceed to check for fuel. Do you smell any gas after trying to start? The carburetors may need cleaned. But I can only guess.
If no gas to the carbs check the fuel filter. If there is a problem with fuel line or filter, flush out the tank and lines before you try to run it into the carbs. If you have fuel to the carbs and spark odds are the carbs need cleaned.
The bike is an 05 with only 4,000 miles. Odds are it sat for a while and bad gas is a good possibility
post #4 of 8 (permalink) Old 04-13-2010, 12:12 PM
you should try the petcock on res and see if it runs. I had a suzuki bandit that would only run on reserve becuase the petcock was all gummed up.....
Emperor Wurm is offline
post #5 of 8 (permalink) Old 04-13-2010, 11:37 PM
Hi i have a question on gas additives,is their any type of additive i can ad to my gas
to clean the carb.I have no running issues just wondering if this is a good idea to keep everything lubed and clean?
Dseidel is offline
post #6 of 8 (permalink) Old 04-14-2010, 12:21 AM
Fulltilt1's Avatar
Sea Foam, get it at Walmart
Fulltilt1 is offline
post #7 of 8 (permalink) Old 04-15-2010, 09:13 AM Thread Starter
Bought a bottle of Sea Foam and 2 new spark plugs from NAPA. The bike fired right up without the choke being on! Thanks for all your help!!
post #8 of 8 (permalink) Old 04-15-2010, 09:46 AM
Fulltilt1's Avatar
I Love a Happy Ending!
