950 Rear Shock Adjustment - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 6 (permalink) Old 06-04-2010, 03:30 PM Thread Starter
Just wondering if anyone has adjusted the rear shock on the 950. My 950 (not tourer model) was set on the fourth notch. I am going on a trip to Gettysburg this summer on the Lincoln Highway (about 450 miles one way). I got a luggage rack put on and a 19.5x19.5x11.5 luggage piece. So, a good size luggage. My wife weights about 135 (make sure she doesn't see that number). I adjusted the shock to 6th notch to compensate for the additional weight. Was wandering if I should go another notch. Anyone got ideas.
Suds
Suds is offline
post #2 of 6 (permalink) Old 06-04-2010, 11:18 PM
Tonydtiger1971's Avatar
How do you adjust shocks?
Tonydtiger1971 is offline
post #3 of 6 (permalink) Old 06-05-2010, 09:21 PM
Springs
You are actually adjusting the rear springs. If you look at the shock you will see. Assuming you have an older model V star. Some of the newer bikes like the 950 & Liner have a single spring under the swing arm and you adjust it there. The wrench probably came with the bike.
post #4 of 6 (permalink) Old 06-06-2010, 07:37 AM Thread Starter
LinerDave,
It looks like you got a 950 Tourer in the picture loaded down. What was the rear spring setting on our bike from factory? Was it on the 4th notch or on a higher setting?
Thanks,
Suds
PS: Thanks for the correction that it is actually the spring adjustment not the shock.
Suds is offline
post #5 of 6 (permalink) Old 06-06-2010, 05:01 PM
Well now I feel like a dork too.
post #6 of 6 (permalink) Old 06-06-2010, 09:16 PM
Bike
Suds,
Tough to tell in the small picture and most of the new models look a lot alike but my bike is a Stratoliner.
It has a single shock and spring under the swing arm. I have not changed it. I have been thinking of tightening it a little. When wife and I both get aboard the head light comes up a little.
Don't even be concerned about asking a wrong question. We are here to learn.
