2005 100 - Front head tightening - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 12 (permalink) Old 10-30-2010, 07:44 PM Thread Starter
Conley's Avatar
I am presuming that occasionally checking/retorquing the heads are part of regular maintenance at 50k or so. The front head, or whatever that top part is called, is leaking in the fins. I checked the valve adjustment cover and it is tight. The leak just started about a week ago after some heavy riding for about 400 miles.
I am hoping the answer is yes, you need to retorque them every once in a while. I would hate to have to pull the heads for a new gasket.
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
Custom front turn lights
large saddlebags
engine accent lights
wide seat
Kuryakyn Tombstone LED rear light set
ORK 5/8 line
POD MOD
Conley is offline
post #2 of 12 (permalink) Old 10-31-2010, 02:09 PM
Fulltilt1's Avatar
Are you sure it's leaking from the head and not the cam chain sprocket cover. It's easy to cut an o-ring when adjusting the valves.
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #3 of 12 (permalink) Old 10-31-2010, 08:11 PM
IF a head gasket is blown there is no re torquing. If it is leaking it will require replacing....
oldbanjo is offline
post #4 of 12 (permalink) Old 11-01-2010, 11:15 AM Thread Starter
Conley's Avatar
If the head gasket was leaking, I would expect most of the whole head area to leak. There is oil above seeping above the head gasket, in the upper fins, so I think I can rule the head gasket out.
Also, I believe if the head gasket was blown, I would get an uneven run on the engine and notice a bit more backfiring I guess. It may be the cam chain cover.
I will check out putting a new cam chain cover gasket on and see if that does the trick. I think that may be it.
Thanks for the replies y'all!
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
large saddlebags
wide seat
ORK 5/8 line
POD MOD
Conley is offline
post #5 of 12 (permalink) Old 11-03-2010, 02:48 PM Thread Starter
Conley's Avatar
Looks like it may be the tappet cover. There is fresh oil on the bolt and only on the front of the engine above the head gasket line. All of the oil ion the fins are at the tappet cover level or lower in the fins and seems to be more concentrated at that level.
I have not even put 1000 miles on the last valve adjustment from the shop. I wonder if there is a bad gasket on the tappet cover, or even if it has a gasket.
Thoughts?
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
large saddlebags
wide seat
ORK 5/8 line
POD MOD
Conley is offline
post #6 of 12 (permalink) Old 11-03-2010, 03:25 PM
Fulltilt1's Avatar
Were either of the bolts loose? Maybe not torqued to spec or backed out. The O-ring in question sits flat against the head in a recessed groove on the cover. Maybe they didn't install a new one.
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #7 of 12 (permalink) Old 11-03-2010, 04:18 PM Thread Starter
Conley's Avatar
No, I think they may be too tight.
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
large saddlebags
wide seat
ORK 5/8 line
POD MOD
Conley is offline
post #8 of 12 (permalink) Old 11-03-2010, 04:25 PM
Fulltilt1's Avatar
I'm not sure if "too tight" would distort the cover or not. Time to break out the Metric Hex Wrenches and pull that cover off.
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #9 of 12 (permalink) Old 11-03-2010, 04:28 PM Thread Starter
Conley's Avatar
yeah, I want to have the gaskets first just in case. That is my next course of action. Thanks!
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
large saddlebags
wide seat
ORK 5/8 line
POD MOD
Conley is offline
post #10 of 12 (permalink) Old 11-03-2010, 04:31 PM
Fulltilt1's Avatar
Smart Plan
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
