Headlight= No Light - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 11 (permalink) Old 03-01-2011, 05:56 PM Thread Starter
Unhappy Headlight= No Light
I looked around before making this post with not much success. Head light worked two days ago, now it doesn't. I hooked my volt meter up to the socket my bulb plugs into, no voltage above 0.04. Bad relay or is there a fuse I don't know about? If so locations? I have a. 2005 vstar 1100 classic. I hate driving at 0400 with no headlight to base. Thanks!
Chalms is offline
post #2 of 11 (permalink) Old 03-01-2011, 08:37 PM
Fuse
There is a fuse. It is in the storage compartment on the left side.
http://www.starmotorcycles.com/asset...ustom_1356.pdf
Check the high low beam switch. Be sure you have a ground. If there are passing lamps wired to feed from the headlight you may need a larger fuse. I believe stock is 15 Amp. I would not go larger than 20 Amps.
post #3 of 11 (permalink) Old 03-01-2011, 08:48 PM Thread Starter
thanks! the kid just went to sleep and once I finish cleaning up the kitchen (yes, I'm domesticated), and make some coffee on the stove, its time to see what the problem is! Again, thank you!
Chalms is offline
post #4 of 11 (permalink) Old 03-01-2011, 09:49 PM Thread Starter
ugh............popping fuses like candy! damn you wiring! Instant popping too! Key-off, new fuse in, key-on=pop!
Chalms is offline
post #5 of 11 (permalink) Old 03-02-2011, 12:05 AM Thread Starter
positive to ground in the front turn signal wiring, don't know which side yet..don't care its too late for me tonight. Instead just pulled the wiring and assembly off the front end, i'll just have to ride extra careful tomorrow when i switch lanes.
Chalms is offline
post #6 of 11 (permalink) Old 03-02-2011, 10:02 AM
Fulltilt1's Avatar
from what you've said it's not actually a turn signal problem but a position light. That would be the blue wire in the signal/position wiring harness. This wire is on the same circuit as the headlight power. As shown in fig 1
Fig 1
http://www.sloneservices.com/SilverB...ring-US-01.JPG
fig 2
http://www.sloneservices.com/SilverB...ring-US-02.jpg
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #7 of 11 (permalink) Old 03-02-2011, 10:23 AM
Ohm meter
Chalms,
Sounds like you are in control, but just in case keep in mind the resistance of a cold light bulb is very low. If you think the one Ohm resistance of a cold light bulb is fooling you remove the bulb from the socket. If there is a short it will still be there.
post #8 of 11 (permalink) Old 03-02-2011, 08:47 PM Thread Starter
Thanks guys for the help! I'm going to fix it this weekend, not too worried about having front turn signals. I'll just take caution when changing lanes with people infront of me.
Chalms is offline
post #9 of 11 (permalink) Old 03-02-2011, 11:39 PM
Fulltilt1's Avatar
Should be just a matter of not connecting the blue wire till you fix it and you'll still have signals.
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #10 of 11 (permalink) Old 03-02-2011, 11:45 PM Thread Starter
True! But I pulled the bar and lights off the other day kind of lazy. Being in home port is kicking my butt. Some how I got more sleep during deployment.
Chalms is offline
