07 VSTAR1100 Starting issue - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 6 (permalink) Old 03-18-2014, 10:13 PM Thread Starter
rkturner1100's Avatar
hey Riders
after a 1 month sitting my 07 Vstar1100 is cranking but refuses to fire...
after several times at it gives i get a fuel smell almost like its flooded with any throttle being applied...
the battery is fully charged.
i'm guessing spark plugs but would like a couple suggestions before i starting tearing it apart...
Thanks for any and all suggestions
R
KEEPING MY HEAD UP AND THROTTLE DOWN
rkturner1100 is offline
post #2 of 6 (permalink) Old 03-18-2014, 10:55 PM
Maybe the floats are stuck in the carbs?
russell is offline
post #3 of 6 (permalink) Old 03-18-2014, 11:29 PM
Take a look under the carbs with a flashlight. If there is gas puddled there, likely the floats are stuck. The gas just pours out the overflow on the carbs. You can sometimes unstick them by putting the handle of a wooden hammer on the bowl and TAPPING on the other end with something. If they are stuck, it's probably time for a thorough carb cleaning.
ridgwayrescue is offline
post #4 of 6 (permalink) Old 03-19-2014, 10:41 AM
SThomas's Avatar
This.
V-Star 1100 Silverado
429 cams
Chubby pods
Speedster Slashdowns
Dyna 3000
AIS Removed
64lb clutch
Sappers Forward
SThomas is offline
post #5 of 6 (permalink) Old 03-20-2014, 06:52 PM
Probably dirty carbs. You should never give the bike gas when starting.
06silverado is offline
post #6 of 6 (permalink) Old 03-20-2014, 08:01 PM
Corsair's Avatar
Have you taken the plugs out and what do they look like? What kind of fuel do you use, ethanol or real dino stuff? The bike sitting for a month shouldn't be affected this bad. I suspect that you need to give the carbs a good cleaning. Oh wait a few others said that also
2009 Stratoliner S
Corsair is offline
