**HELP** Stuck Baffle - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 9 (permalink) Old 03-19-2014, 08:54 AM Thread Starter
Ok so I put a set of Cobra Long Shots on my 07 V-Start Customm 1100. Im trying to remvoce the baffles but 1 is stuck. I've had them out before but for some reason the one wont come back out. The set screw nut inside the baffle itself broke off so I cant run the screw in from the backside and pull it out that way. Any suggestions would be greatly appreciated. Thanks in advance!!!
bigbeav82 is offline
post #2 of 9 (permalink) Old 03-19-2014, 09:37 AM
GreenMTNRider's Avatar
Drill it out?
GreenMTNRider is offline
post #3 of 9 (permalink) Old 03-19-2014, 10:49 AM
blueroadstar's Avatar
Originally Posted by GreenMTNRider View Post
Drill it out?
Drill what out? The whole baffle? It would take one heck of a drill bit to do that. Best thing I can think of would be to make a hook out of a piece of steel rod and try to get a hold of the baffle to pull it out.
BLUE BIKE CLUB
2008 ROAD STAR
2008 KAWASAKI KLR 650
2014 Triumph Tiger 800 XC
My ride videos. http://www.youtube.com/user/roadstarblue/videos
Never run out of traction, ideas, and real estate at the same time.
blueroadstar is offline
post #4 of 9 (permalink) Old 03-19-2014, 10:52 AM
Not sure what the baffles look like...But if there is a spot where you could clamp down some vise grips, try that. Pull while rotating the baffle.
2013 H-D FXS Blackline
2006 V-Star 1100 Classic
1980 XS650 Bob (in progress)
1981 XS650
USMC - 0331 - OEF
BP03 is offline
post #5 of 9 (permalink) Old 03-19-2014, 02:19 PM
Sorry I must have misread your post, I thought you said the screw holding the baffle on was stuck.
I would get a pair of vice grips and clamp on and just wiggle and pull...
It wouldnt hurt to use a little PB Blaster in there either...just a word of the wise though any left over in there may cause a little fire ball when you first start up the bike, Im not sure how flammable that stuff is, but it might ignite and blow out the tail pipe (wont do any damage though)
post #6 of 9 (permalink) Old 03-19-2014, 02:42 PM
danman's Avatar
if the nut INSIDE the baffle is turning, then the only way to remove the set screw is to drill or grind off the head of the screw then use a center punch to drive the screw into the baffle. then you should be able to remove the baffle with a pair of long nose vise grips. that sounds like the same set up as my samson exhaust. if you want to reinstall the baffle later on I would use a sheet metal screw. no nut is required for that.
02 Vstar 1100 classic
Samson Warloard Ripsaws
chubby pod kit/maxair pms screws
barons ork
kuryakyn isso grips
breakaway cruise cont.
driver backrest
barons DT risers
barons tackometer
oem passing lights
crome visors on all lights & signals
drag highway pegs
viking studded bags
sissy bar with rack
studded front and rear seats
studded gas tank bib with pouch
clocks for bikes- stem mount
Ram mount& hard wire for GARMIN GPS
Memphis Shades Batwing Fairing
danman is offline
post #7 of 9 (permalink) Old 03-19-2014, 02:43 PM
I Spray the baffle with WD40, then use a cotter pin puller to the inside of the baffle and hook it into the place where the screw bolts in. I then pull on it, sometimes even knock it in slightly and then again pull on it, it always works, sometimes you have to repeat hitting it in and then pulling it out a few times.... This is what it looks like http://www.bing.com/images/search?q=...er&FORM=HDRSC2
2014 Road King (current)
08 V Star 1300 Tourer
07 Suzuki C50 Boulevard
"debt is dumb, cash is king" ... http://www.usdebtclock.org/
alarmguy is offline
post #8 of 9 (permalink) Old 03-19-2014, 03:34 PM
take the pipes off and flip over get a piece of half inch conduit and pound the S&l t out of it.
post #9 of 9 (permalink) Old 03-19-2014, 04:25 PM
That's what she said
russell is offline
