1300 V-Star oil leak - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 7 (permalink) Old 04-07-2014, 09:13 PM Thread Starter
When I changed the oilfor the season I noticed that oil was leaking(small amount) from a chrome piece with two bolts on the bottom of the engine. Does someone know what it is or where it goes? Jim MN
Last edited by vanderlinden_j; 04-07-2014 at 09:16 PM. Reason: Left out the question
vanderlinden_j is offline
post #2 of 7 (permalink) Old 04-08-2014, 08:35 AM
Moneypit's Avatar
Trying to figure out what bolts your talking about. Can you be more specific.
2008/ 1300 V Star
Kuryakyn Pro R hypercharger
Road Burner 2.5" Street Pros
Dyno-Jet fuel processor
Yamaha OEM Passing lamps
Yamaha OEM highway bars Kuryakyn pegs
Tsukayu Strong JUMBO hard bags
Wicked Lightening green LED's
Kuryakyn Triple Whammy
RecklessMotorcycles fairing w/Rockford Fosgate amp
Klock Werk 6.5" windshield
V&H Big Shots for sale
Moneypit is offline
post #3 of 7 (permalink) Old 04-08-2014, 08:40 AM
rmccutchan's Avatar
A picture would help. I can't think of what it could be either.
rmccutchan is offline
post #4 of 7 (permalink) Old 04-09-2014, 10:14 PM Thread Starter
Here is where the oil was leaking(or moist) from. Hope this works. Jim MN
post #5 of 7 (permalink) Old 04-10-2014, 06:27 AM
That is the drain tube for your combined oil pump and water pump.
The water pump and oil pump are in one assembly in the oil pan, if the water pump ever leaks coolant, it should come out of that tube instead of leaking into your oil.
It is common for a tiny amount of coolant to be present at that spot, if it is oil on that spot, its possible that maybe an "O" ring needs to be replaced.
I do not know much more then that, hope this helps.
2014 Road King (current)
08 V Star 1300 Tourer
07 Suzuki C50 Boulevard
"debt is dumb, cash is king" ... http://www.usdebtclock.org/
alarmguy is offline
post #6 of 7 (permalink) Old 04-10-2014, 10:22 PM Thread Starter
Then in order to fix it I should drain both oil and antifreeze? I can't find part numbers for the o-rings or gaskets. Jim MN
post #7 of 7 (permalink) Old 04-11-2014, 06:26 AM
What I posted above is all I know. Are you sure its oil and not anti-freeze?
From what I read it is quite common for that area to have a drop or two of anti-freeze or oil on it. If it is more then that, meaning dripping onto the floor that might be another case.
alarmguy is offline
