No idea how hard it is on a 1300 but I just did it on the 1100 for the first time. It helps A LOT to have someone around who knows what they are doing. I would have screwed it up completely without help. Also, you need a few specialized pieces of equipment - do you have all that stuff on hand?
The actual adjustment is pretty easy if you know what you are doing...
I have someone who has the tools I don't have and he has some experience on older vstars. I was hoping to watch a short video or slide show just so I can see what I am getting into.
Well be prepared for a long day... the engine needs to be cold when you do this.
You will be removing the tank (on the 1100 that means removing the seats) and the airbox. Next you remove the spark plugs. Then you take off the valve covers and remove two bolts on the engine cover. Then you rotate the crankshaft until the valves on one cylinder are both closed (you can tell because they will move slightly with finger pressure) and stick in the measuring tool. Adjust as necessary both front and back to spec. Move onto the other cylinder and repeat. Put the bike back together in reverse. I would watch any valve adjustment video for a V-twin on Youtube. The general concept will be the same and the specifics for your bike will be in your manual.
Good luck and have fun!
Related Threads
Yamaha Starbike Forum
352K posts
33.1K members
Since 2008
