2002 VStar 1100 Classic Clutch Slip - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 5 (permalink) Old 04-28-2015, 12:11 PM Thread Starter
Looking for inputs - bought an 02 VStar 1100. The clutch works well at a decent level of acceleration but slips when the throttle is hard cranked. Of course seller claims clutch plates are supposedly new, and I checked the cable adjustment and it appears to be good.
So - before I go tearing into the clutch, does anyone have ideas? Fully understand this is a wet-clutch and some oils can cause slippage. Do the new friction discs have a break-in period?
Thanks in advance....
bigdaddyl is offline
post #2 of 5 (permalink) Old 04-28-2015, 12:53 PM
I can't answer about break-in and such but did you verify proper adjustment of the lever on the transmission end of the clutch cable. Mine started slipping last fall and turned out a small adjustment here solved my issue. If you have a repair manual it will detail how to make this adjustment.
As you mentioned, incorrect engine oil can cause this as well. I would exhaust all the options before tearing into the case.
2006 V-Star 1100 Classic
Completely debadged
Floorboard extensions
Kuryakyn grips
Passenger floorboards
Barons Nasty Boy Slip-ons
Maxair pods
Mustang seats
Kuryakyn led headlight halo
Summer is offline
post #3 of 5 (permalink) Old 04-28-2015, 06:58 PM Thread Starter
Thanks - I'll have to check that out - I only checked the lever adjustment. I downloaded the manual so lemme have a look.
post #4 of 5 (permalink) Old 04-28-2015, 10:24 PM Thread Starter
Summer - that did the trick....bike runs like a raped ape! Thanks
post #5 of 5 (permalink) Old 04-29-2015, 07:36 AM
Glad it worked for you. I can't take the credit as I learned it the same way you did, from the knowledgeable folks here on the forum. Take what you learned and help others here and elsewhere.
Completely debadged
Kuryakyn grips
Maxair pods
Mustang seats
Summer is offline
