09 Yamaha V-Star 950 bogs when accelerating - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 5 (permalink) Old 07-11-2015, 03:48 PM Thread Starter
Hey guys I have 09 Yamaha V-Star 950 with 3,000 miles. Whenever I'm at a stop sign or stop light when I go to accelerate and run thru the gears it bogs, feels like it takes forever to get up to 50-60mph. Could it maybe be throttle position sensor (TPS) or something is wrong with my fuel injection system.
Pattersonjacob11 is offline
post #2 of 5 (permalink) Old 07-12-2015, 03:57 PM
Dairy Guy's Avatar
I always start with the simple, I suggest changing the spark plugs, and drain the gas
Dairy Guy is offline
post #3 of 5 (permalink) Old 07-12-2015, 06:13 PM
do you hear the RPMs revving up equally with twisting the throttle?
bevo1981 is offline
post #4 of 5 (permalink) Old 07-13-2015, 08:33 AM
jwallick55's Avatar
Have you done anything recently where you had to disconnect the battery cables? Every time I did something electrical on my bike, it took a couple of days for the ECU to catch up to my riding.
I know you said that there is only 3000 miles on the bike, but have you checked your air filter? If you're not getting enough air, the computer won't give more gas to the motor for acceleration.
Just throwing these things out to help you diagnose before you need to take it to the shop.
jwallick55 is offline
post #5 of 5 (permalink) Old 07-13-2015, 10:16 AM
commonground's Avatar
A 2009 with 3,000 miles probably means that it has set idle a good bit. That could mean fuel delivery problem. I would check the fuel filter also. Augie
commonground is offline
