1100 ned front brake pads (EBC) now noise? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 12 (permalink) Old 05-24-2012, 08:35 PM Thread Starter
Ken448's Avatar
1100 new front brake pads (EBC) now noise?
INstalled pads all around today since I was replacing the rear tire. Took it for a spin and man what a diff the tire made BUT now I have a sound coming from the front wheel that sounds similar to a Cicada (bug) when I get above 10mph, and I can gear it on a jack when its in the air as well. Went through the brake calipers again, cleaned pistons and lubed them a tad, lubed the sliders on the caliper and gave the rotors a once over with some 400 grit thinking the holes may be catching the brand new pads. Put it all back together, no luck. No noise at all when the calipers are off and the wheel is spinning.
if you dont know what a Cicada is then....
Ken448 is offline
post #2 of 12 (permalink) Old 05-24-2012, 09:01 PM
aide's Avatar
Give your pads a few hundred k to work in.
aide is offline
post #3 of 12 (permalink) Old 05-24-2012, 10:11 PM Thread Starter
Ken448's Avatar
Ken448 is offline
post #4 of 12 (permalink) Old 05-24-2012, 10:13 PM
aide's Avatar
I just put new ebc HH pads on and the package said 200km for break in.
aide is offline
post #5 of 12 (permalink) Old 05-24-2012, 10:31 PM Thread Starter
Ken448's Avatar
wait.. theres words on the package? Man Im gonna have to go read the directions now
Ken448 is offline
post #6 of 12 (permalink) Old 05-24-2012, 10:33 PM
HTMNKYLVE's Avatar
Had the same sound when i replaced my pads and was still there after 500 miles. I took the pads back to the dealership and they replaced them with a new set of pads. The new pads they gave me are heavy duty. The one thing i noticed about the pads that made the noise is that they did not have a slot in the center of the pad. My educated guess is that because there was no slot the gasses were building up in the drilled rotors and did not release until the holes passed the plane of the edge of the pad, with the slot in the center of the pad the gasses did not build up as much. I will update when i put on the new pads.
SMELL MY FINGER
RED BIKE CLUB It's Lonely At The Top
HTMNKYLVE is offline
post #7 of 12 (permalink) Old 05-24-2012, 10:39 PM
aide's Avatar
/http://www.ebcbrakes.com/troubleshooting.shtml
aide is offline
post #8 of 12 (permalink) Old 05-25-2012, 08:34 AM
Fulltilt1's Avatar
Did you lubricate the backside of the pads? I usually tape mine off and spray with graphite on the backside, never get a squeak. Thats why they always try to shove that little packet of grease at you at Autozone when you buy pads.
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #9 of 12 (permalink) Old 05-25-2012, 10:02 AM
Also drilled rotors will usually always make a strange sound compared to non drilled, especially with new pads.
post #10 of 12 (permalink) Old 05-25-2012, 10:43 AM Thread Starter
Ken448's Avatar
indeed.. Did a little riding today and its now getting louder when the brakes are applied.
Hope it subsides, I have a "paranoid" ear and very good hearing.. 2 bad things.. LOL.. so, lets not get started on the ticking that has developed as a result of switching to M1 15w50 grrrrrrrr
Ken448 is offline
