650 custom not starting up - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 7 (permalink) Old 08-07-2015, 03:37 AM Thread Starter
So, I just received my v-star 650 custom from the moving company, and she looks in pretty good condition, but she's protesting. So, I'll start with this: I'm new to motorcycles in general and have never had to ship my bike overseas until now. Before I left, I drained the fuel tank, and that was it. She went on a boat for 3 months, and now she's here. I filled up the tank with fuel, and tried to get her started. It was making a ticking sound after trying to getting it going. I opened the choke, and gave it gas, and after a few tries, it'll start and as long as I give it plenty of gas, it'll stay on, but then moment I ease off the throttle, she'll idle for about 10 seconds, then die. What's going on? I don't know where there's a dealer around here and even if there was, I wouldn't be able to get it there. Am I over reacting? HELP.
alam2010 is offline
post #2 of 7 (permalink) Old 08-07-2015, 03:52 AM Thread Starter
Upon further inspection, when I'm able to get it started, it'll go, but I noticed it's leaking fuel somewhere.
alam2010 is offline
post #3 of 7 (permalink) Old 08-07-2015, 05:45 AM
http://api.viglink.com/api/click?for...13811958515098 650 vstar forum might be some help,leaking fuel could be a stuck float. 90% of problems are dirty carb they have to be taken apart and clean the jets and blow out all internal passages with carb cleaner.
post #4 of 7 (permalink) Old 08-07-2015, 05:52 AM
post #5 of 7 (permalink) Old 08-07-2015, 06:12 AM
farmalldanzil's Avatar
Originally Posted by alam2010 View Post
. It was making a ticking sound after trying to getting it going. I opened the choke, and gave it gas, and after a few tries, it'll start .
The ticking is the fuel pump...normal. gave it gas.... will make toast out of your starter clutch as this changes the timing. Don't touch the gas when starting.
farmalldanzil is offline
post #6 of 7 (permalink) Old 08-08-2015, 07:48 AM
BigBuddha76's Avatar
yes, sounds like dirty carb
ISRA #4642
98 VStar 650 Classic
Ignant is Bliss
BigBuddha76 is offline
post #7 of 7 (permalink) Old 08-10-2015, 12:17 PM
motohead's Avatar
It sounds like you're leaking fuel through the carb vent tube. Look between the heads and you should see a rubber tube coming from between the carbs. If fuel is coming out there you have a stuck float or gummed up needles in the carb. You can try replacing the fuel filter and pouring in some Seafoam, try starting it, and letting it sit for a couple of days. If you're careful you can pull the bowls and spray some carb cleaner in there. If that does not work you will have to pull the carbs and clean them. Not hard, just a PITA.
motohead is offline
