04 V Star 650 Swapping Between Classic and Custom Fenders - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 11 (permalink) Old 09-22-2016, 03:42 PM Thread Starter
Hello new to the forum. I recently purchased an 04 V Star 650 Classic however I really liked the Custom rear fender and would like to know if swapping the two is easy as just unbolting and replacing? Has any one done this? From the pictures I've looked at it looked like they're using the same brackets to hold up the rear fender. Then again I can't tell if the seats are the same. Thanks!
Sent from my SM-N920T using Tapatalk
nkSolar08 is offline
post #2 of 11 (permalink) Old 09-22-2016, 09:48 PM
BigBuddha76's Avatar
seats are different
ISRA #4642
98 VStar 650 Classic
Ignant is Bliss
BigBuddha76 is offline
post #3 of 11 (permalink) Old 09-22-2016, 10:21 PM
07midnightcustom's Avatar
If i remember correctly it is not a straight up swap.
07 vstar 650 midnight custom
Ais disable, 4.5 inch risers, V&H cruzers, jetted with pods, viking saddlebags, Kuryakyn mini boards and memphis fats windshield, fuel solenoids deleted, star solo seat and 4 inch extensions. Boss audio sound system.
07midnightcustom is offline
post #4 of 11 (permalink) Old 09-23-2016, 07:03 AM
farmalldanzil's Avatar
You can always cut the offending part off and then you will have a custom.
farmalldanzil is offline
post #5 of 11 (permalink) Old 09-23-2016, 09:12 PM
your turn signal and license plate holder will not be in the same place
you need more than just the fender
post #6 of 11 (permalink) Old 09-24-2016, 06:20 PM Thread Starter
Thanks for the replies, it looks like I would need everything the comes on the rear fender.
post #7 of 11 (permalink) Old 09-24-2016, 07:00 PM
that won't work the edges will need to be rolled
post #8 of 11 (permalink) Old 09-25-2016, 10:01 AM
wft???????
if you just cut off the offending part the sheet metal will rust out in no time, on the oem fender the edges are folded back, so after you cut off the offending part you would need to fold the edges and that is not easy to do especially when you get to corners, there's a right way to chop fenders and a wrong way and just cutting off the offending part of a fender is the wrong way, because you'll be chasing rust for life of the fender. if you leave a sharp edge just painting the cut edge will only stop the rust for a short time, you would have to constantly check the edge for rust and and re sand and paint as necessary and who really needs that, i'm only speaking from my experience other's may have had better results doing it your way
post #9 of 11 (permalink) Old 09-26-2016, 01:53 PM Thread Starter
Thanks for sharing your experience pauli466. I've dealt with rust on cars in past, it's definitely no fun.
I found some rear fenders on ebay but they don't come full with lights and turn signals, looks like it will be much harder to find the set than actually swapping it.
BigBuddha76 - The main seat does look different.
post #10 of 11 (permalink) Old 09-29-2016, 01:19 PM
I have a smoothed out rear fender if your interested (stock holes for the taillight and stuff are smoothed over). Next week I'll have a stock classic fender with the tail light, turn signals and the classic seat.
bones11 is offline
