Hello from Nova Scotia Canada - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 13Likes
post #1 of 12 (permalink) Old 02-13-2019, 10:49 AM Thread Starter
Getterdunn's Avatar
I bought a new to me Vstar 650 classic with 2500kms on it in 2018. Love this bike! Starting to change few bits on it to make it more suitable to me. Looking forward to tech help from this group and to look at some other members sweet rides! Safe travels to all!
Keith Post and KCW like this.
Getterdunn is offline
post #2 of 12 (permalink) Old 02-13-2019, 11:13 AM
NorthernRider's Avatar
Howdy, neighbor! Welcome from NB. You found a great place to swap stories and info about your VStar. I've had my 1100 for 2 years now and I've made many trips to NS with it. Good, solid, reliable bikes. It's never let me down.
Love to see a pic of yours and some of the mods you've done.
Keith Post likes this.
Paul
2007 Vulcan Nomad
V&H exhaust
All stock except for:
Kuryakyn Grips
4" Risers
NorthernRider is online now
post #3 of 12 (permalink) Old 02-13-2019, 12:16 PM Thread Starter
Getterdunn's Avatar
I have modified the clutch handle to replicate the clevver lever. Tinted signal lights. I am currently trying to install a aftermarket daymaker headlight. But in doing so I somehow damaged my headlight system. I installed my factory headlight and it won't work? No low or high beam. No HighBeam indicator light on the tank.
post #4 of 12 (permalink) Old 02-13-2019, 12:21 PM
Hopefully you only shorted a wire and blew the headlight fuse... easy thing to replace.
post #5 of 12 (permalink) Old 02-13-2019, 12:32 PM Thread Starter
Getterdunn's Avatar
I have checked the headlight fuse, it's fine. Is the headlight relay a possible issue? If so, is that the relay with two 30amp fuses in it? Also if so, 😀 how do I test these issues? I have two months to figure this out and get the new light installed.
post #6 of 12 (permalink) Old 02-13-2019, 12:45 PM
Welcome from Houston, Texas. Glad you joined us. Here's a few interesting threads to check out when you get a chance.
Ride often and safe.
post #7 of 12 (permalink) Old 02-13-2019, 12:58 PM
I cant dig into the schematics right now
but if you google V star 650 service manual, you should be able to find the yamaha factory manual online as a free download in pdf format
the schematics are near the last page of the manual. I dont know if the 650 has a headlight relay, 30A is way too much current to be a headlight fuse, you might be looking at the starter relay?
Again Im guessing right now, if you need answer quickly google the manual, its easy to read the schematics, and the colors of all the wires are also called out on it.
post #8 of 12 (permalink) Old 02-13-2019, 01:13 PM Thread Starter
Getterdunn's Avatar
I have the manual, thank you for the direction. I even printed it off to give me some downtime reading. I'm curious as to what they mean when they are talkiing about checking the meter connector? Where is that at? I know where the headlight connector is.
post #9 of 12 (permalink) Old 02-13-2019, 01:35 PM Thread Starter
Getterdunn's Avatar
Since I haven't run my bike for close to 4 months. I didnt realize that the headlight doesn't come on unless the bike is running. I was trying to keep her in hibernatetion until the warmer weather was here and ready to ride. So I clenched my teeth started it up and wouldn't you know it. The light works.....😀now to figure out which of the wires that are attached to the harness go? It is a halo design that also has a signal light halo that activates when the signals are turned on. That's my girl in the last pic!
ID:	83376   Click image for larger version
ID:	83378   Click image for larger version
post #10 of 12 (permalink) Old 02-13-2019, 01:40 PM
I dont know what the meter connector is. If they are testing the high beam indicator it might be one of the connectors to the instrument cluster on the gas tank?
if you look on the schematic they have names for all the connectors.. maybe its a typo, or something that did not translate well from Japanese?
I was not aware that newer 650s hold the headlight off until the bike starts. I know some of the bigger Vstar bikes do that, my 2005 Vstar 650 has the headlight on with the key switch.
I guess 2006 was the year they added that function.
Glad it was something easy to debug, and you are not tearing the wiring harness out of your bike.
Hello from wet & cold Nova Scotia Bryan_Campbell New Member Introductions 12 02-04-2017 03:16 PM
NOBI Nova Scotia Canada nsSteve New Member Introductions 5 06-03-2015 11:23 PM
2006 Road Star, Nova Scotia ChilliWillee New Member Introductions 9 04-12-2012 09:18 AM
New from Nova Scotia, Canada clicker666 New Member Introductions 21 09-28-2011 06:58 PM
halifax, nova scotia, canada the wifes mechanic New Member Introductions 3 07-24-2010 08:01 AM
