09 950 v star smaller rear pulley - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 6Likes
  • 1 Post By 950 v star
  • 1 Post By bevo1981
  • 1 Post By lesblank
  • 2 Post By bevo1981
post #1 of 9 (permalink) Old 03-09-2019, 10:38 AM Thread Starter
Has anyone swapped out their rear pulley on a 950 v star for a smaller pulley to reduce rpm's at highway speeds? If so, what pulley and how many teeth and did belt need replacement for shorter one?
Keith Post likes this.
950 v star is offline
post #2 of 9 (permalink) Old 03-09-2019, 12:29 PM
howdy. several have swapped out the front pulley with that of a stryker to reduce RPMs. it has 31 teeth. no belt replacement is needed.
bevo1981 is offline
post #3 of 9 (permalink) Old 03-09-2019, 06:03 PM Thread Starter
Thanks...but have already made that swap. It certainly helped, but not by much. Still would like to find a smaller rear pulley...
post #4 of 9 (permalink) Old 03-10-2019, 11:43 AM
been going online in 950 forums for a decade and can't recall ever seeing someone post about swapping out the rear pulley. not sure which would match.
bevo1981 is offline
post #5 of 9 (permalink) Old 03-12-2019, 07:09 PM
Welcome from Houston, Texas. Glad you joined us. Here's a few interesting threads to check out when you get a chance.
Ride often and safe.
post #6 of 9 (permalink) Old 03-13-2019, 06:04 PM
Welcome to the forum from East Tennessee and a fellow 950 rider. Haven’t read or heard of anyone swapping out the rear pulley, but someone may know about it. Any pics of your 950 you’d like to share with us?
post #7 of 9 (permalink) Old 03-13-2019, 06:47 PM
Here's a thread that might help.
https://www.starbikeforums.com/forum...y-tonight.html
post #8 of 9 (permalink) Old 03-13-2019, 08:08 PM
this comes up frequently with the smaller engine vstar bikes
If you are use to riding a Harley with its long throw low RPM engine, then vstar bikes will sound and feel like the engine is rev'ing too fast. But the Vstar engines are made with wider pistons with a shorter throw length. Vstar bikes rev higher, and they have more power per CC.
When I got my license I was planning to get a HD Iron 883. Its rated at 45HP. A VStar 650 is 40 hp. For the displacement increase an 883 would be 54HP if they used the vstar engine format.
People do some bad things to Vstar bikes to make them feel and sound more like a HD. For one, they reduce the idle speed. Its suppose to be 1200 rpm. If you slow it down so it putt putt putts like a HD, the oil pump will not build enough pressure at idle to keep the overhead cam bearings pressurized and flowing with oil.
Depending on which bike you have, the lower compression engines will let you ride with the RPMs down pretty low, as long as you dont let it drop below ~1500. On my 650 I can take corners in 3rd gear, and I can ride thru town at 35 in 5th gear. The engine will not shudder or balk. When I get to the edge of town and the speed limit changes to 55, rotate the throttle up and the bike winds right up to 60 all in one smooth climb, picking up HP as it gets to the higher rpms.
Its a surreal feeling, the bike accelerates faster at the higher speed, because the engine is reaching its peak HP rpm.
I get that it sounds like it needs another gear at 75mph, but it doesnt. Its designed to run that way, and it will run at 80mph all day long.
The bigger engines, like the 1300 on the Royal Star V4, and the 1600 and 1700 bikes have a higher compression ratio. Not high enough that you cannot use regular octane gas, but they will shudder if you let the engine rpms drop too far, and then get on the throttle hard.
The Royal Star has a great transmission gearing for cruising. 5th gear is 0.75, and its a V4. At 80mph its just purring along, and sounds great with its quad independent exhaust pipes.
Im really pleased with the two bikes I have now, the 650 is great for commuting, riding around town and the 1300 Royal Star comes out of the garage for longer road trips, and riding at higher speeds.
I paid $3300 for the VS650 6 years ago and have put 25k miles on it, and paid $2500 for the Royal Star last fall. I could easily spend that much total on just one HD bike, and not have the same utility.
post #9 of 9 (permalink) Old 03-13-2019, 11:01 PM
Originally Posted by lesblank View Post
i THOUGHT he did! but i looked and looked and couldn't find that post so.....
bevo1981 is offline
What are the smaller lights called 98vstar V Star 8 09-16-2015 10:46 AM
Smaller levers tankerman Royal Star 1 04-24-2015 05:56 PM
I swapped my 1300 Front Belt Pulley out for a Stryker Front Belt Pulley alarmguy V Star 42 02-01-2015 04:49 PM
Smaller Engine Guard (highway bar) avail for 950? SkatKat V Star 1 08-22-2012 06:20 PM
Where to find the smaller crash/highway bars SkatKat V Star 8 05-04-2011 08:07 PM
