2000 road star - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 2Likes
  • 2 Post By Yamaha Pat
post #1 of 6 (permalink) Old 06-04-2019, 01:11 AM Thread Starter
2000 road star
intake was cracked,changed,removed ais system,new plugs oil filter,cant find vacumn diagram,just poping badly,vac linnes hooked up right? run p00rly vacumn gauge bouncing fast both extremes up and down vacumn leak? please help senior vet retired union electrician IBEWLOCAL449,LIVING IN HOMER ALASKA summer very short cant ride deperate!thanks guys
Carey Lurus is offline
post #2 of 6 (permalink) Old 06-04-2019, 07:55 AM
Yamaha Pat's Avatar
Welcome from Sacramento, Ca. You will get more responses if you put your question in the Road Star section.
Cherry 2007 650 Classic
Yamaha Pat is online now
post #3 of 6 (permalink) Old 06-04-2019, 04:24 PM
Welcome from East Tennessee Carey!
Share some pics when you can. Itís true, post your questions in the Road Star section and youíll get answers. Glad to have you!
post #4 of 6 (permalink) Old 06-04-2019, 06:49 PM
Welcome from Houston, Texas. Post your issues in the appropriate forum for best exposure and responses with as much detail as possible. Here's a few interesting threads to check out when you get a chance.
https://www.starbikeforums.com/forum...on-garage.html
Ride often and safe.
post #5 of 6 (permalink) Old 06-04-2019, 07:16 PM
here is the link for the Road Star factory service manual - you can read it online and save it to your computer as a pdf file:
http://www.werder.ee/Manual/XV1600.pdf
there must be a section on the vacuum lines in there somewhere.
post #6 of 6 (permalink) Old 06-04-2019, 07:22 PM
^ after looking at the manual a bit, I dont think there is a vacuum system or diagram, its not like the bike has a vaccum assist brake booster or a PCV or vacuum advance.
I think there is only the cap on the vacuum test port on the intake side of the carb, that you would use to attach a vacuum gauge set for balancing the carbs.
If the AIS system has been disabled and now the bike is not running well, there might be a hose or plug that is leaking air - lots of people remove it completely to make the engine look cleaner, but you have to fully plug off all the ports.
the other possibility is you have a vacuum leak, which you can usually locate by pointing an un-lit propane torch at the intake boots, manifold, carb connection to the air intake box... if the idling engine speeds up you are pointing the propane flow at a vacuum leak.
you said the boot was replaced, maybe the seals are not right, or the boot is on backwards.
