07 650 headlight relay - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 5 (permalink) Old 07-19-2015, 09:06 AM Thread Starter
I am looking for info on headlight relay. part number and location please. My bike blows the headlight fuse when key is activated. As I understand it there is no power to headlight until engine is running so there shouldn't be a problem in the wiring from the dimmer to light. just working backwards from switch. please help.
PREACHERMAN is offline
post #2 of 5 (permalink) Old 07-19-2015, 10:30 AM
feel free to vote for bike of the month and submit your own for voting
https://www.starbikeforums.com/forums...isplay.php?f=7
and please take our census
https://www.starbikeforums.com/forums...ead.php?t=5655
be sure to ask in the V Star section here
bevo1981 is offline
post #3 of 5 (permalink) Old 07-19-2015, 03:32 PM
eGo
Welcome from Southern MD!!! I haven an 1100, not sure where the relay is on a 650
eGo is offline
post #4 of 5 (permalink) Old 07-19-2015, 04:33 PM
sonysnek's Avatar
Hey Preacherman, welcome to the forum from southwestern PA. Patient, and I'm sure someone will help ya out. I too have an 1100 so sorry can't help ya with the specifics. Good luck with fixin yer problem though.
Sonysnek
sonysnek is offline
post #5 of 5 (permalink) Old 07-19-2015, 07:36 PM
farmalldanzil's Avatar
There is no relay. Check for voltage at the fuse with the bike running. It shouldn't be more than about 14.7 volts....
if its 15-17 or higher your voltage regulator is blown and needs replacing...if its within spec then you probably have
a short somewhere in the power wire to the headlight that's touching ground (the frame)
farmalldanzil is offline
