- Reaction score
- 14
Hey all, I performed the LED conversion on my RSTD's headlight and passing lights (see below) and would like to upgrade my oem front turn signals over to LED switchbacks (white light running; amber light turning). I made the incorrect assumption that the front signal bulbs were standard 1157 with two contact points and two offsetting seating "pins" on the bulb base, and the conversion would be plug and play. But upon removing the stock amber bulbs learned that they have THREE PINS that seat them properly in the socket. Unfortunately, the LED replacemtns I ordered exhibited the standard 1157 base details described above. In ther past, I've ground off extra, "unwanted" mounting pins that prevented the bulb's installation. But in this case I examined the position of the pins relative to the contact points and realized the contact points of the bulb will not align correctly with the contacts in the socket, once seated, regardless of which two pins I'd grind off. I viewed an LED signal conversion vid on YouTube, (
) and in it, the guy simply inserted the 1157 LED bulb equivilents he ordered online into the socket (at 3:11 into the vid) and presto, they inserted without issue and worked perfectly when he activated his turn signals. He made no mention of modifying the bases of the LEDs he installed. Am I missing something? Can anyone shine some light (no pun intended) on this mystery or have some techniques they've applied in converting their RSTD front signals to LED switchbacks? (BTW - I know I'll be required to install a proper flasher relay to avoid hyper flashing if I am ever able to complete the conversion). Thanks in advance for any and all input! - Don
