Late last summer I was out riding for several hours, in 95° heat, and then stopped at a friend's for dinner. Bike sat for probably 2-3 hours and went to start it and had nothing, no click, no lights, completely dead. Turned ignition on and off several times and nothing.
Was in the process of removing the battery cover, to check connection, and my friend turned the key back on, and lights etc came on as normal.
Rode home, all good, and kinda forgot about it.
Out again a few weeks later, another HOT day, and electrics died while riding. Check engine light was on, but no speedo, no lights / signals, no odometer. Engine kept running, so got it home. Every time I'd slow down at a stop sign dash would flash on and off intermittently.
Noticed a couple of times if I held the turn signal switch one way or the other, dash would come back on (but speedo didn't work).
But then bike was completely dead. Battery at full voltage, but nothing getting to the bike.
Replaced reg/rec with the 05 Road Star unit late 2020. Never had any other electrical issues.
Bike seat over the winter and I finally started looking at it today.
Checked the ground to start with. All clean, good connection.
Battery at ~12.5v.
Turn the key on, and everything looks normal. Hit ignition and electric all dies instantly. Display, lights, everything dead.
Turn key off. Same thing a couple of times.
Then nothing when the key is turned on.
Hooked up multimeter, and still getting ~12.5v, but as soon as I turn the key on, it's reading <1.5v, a couple of times, reading even down in millivolts.
Battery was replaced with the reg/rec in late 2020. Taking it to get load tested in a couple of days, but to my (amateur) eye, seems odd that not even the display is coming on when the battery is still reading to charge with the key off.
Was previously suggested that reg/rec might be bad, but can't start the bike to test.
Loathe to fork out for a new one if that's not the issue...
Battery at ~12.5v.
