Starter
Darrel,
I'm not expert but, the dimming instruments sound like heavy current is being drawn from the battery. I see this if my bike has sat for a while in cold weather. I sometimes put a trouble light under it for heat.
Is your battery a good quality one? Seems like 210 cold cranking Amps is the area. Is your charging system working OK? Your battery should measure 12.7 volts sitting with key off. After starting the bike the battery should come up to about 14 volts.
That's about it for me. Check this site for a hint.
http://www.sloneservices.com/SilverBack/VStar1100-FAQ-08.htm#Starter
Darrel,
