1 - 2 of 2 Posts
I would check for 12 volt at the headlight socket. The diagram below shows which wire is which. If you have power the bulb is bad. If no power check for power at switch. Post back testing results.
Here's a pretty good video on headlight switch testing. The operation of most switches are the same.
https://youtu.be/Ob4JWFQ6aTc
1 - 2 of 2 Posts
