I've searched the forums and can't find a definitive answer. I'm wanting to get 12" ape hangers and use stock risers. Will I have to get extended cables or will stock cables work?
I can’t tell by the picture, but did you reroute your cables behind the forks? I’ve read that you can get by with taller handlebars if you rerouted your brake and clutch cables.I have 8" Biltwell Chumps on 3" risers = 11"
While the throttle cable and clutch cable could go a bit more the brake line is pretty much at it's limit and would have to be extended if I went up another inch or two more.
This might be a better view. All stock cables and brake line. The brake line is pretty much at it's limit, clutch and throttle still have some slack.I can’t tell by the picture, but did you reroute your cables behind the forks? I’ve read that you can get by with taller handlebars if you rerouted your brake and clutch cables.
Yea. That’s a good angle. I’m gonna have to get extended cables. I found an eBay retailer that will make custom brake lines. Now I just need to find clutch and throttle cables that aren’t outrageous expensive.This might be a better view. All stock cables and brake line. The brake line is pretty much at it's limit, clutch and throttle still have some slack.
You can save a bit of money by ditching the "push" throttle cable.Yea. That’s a good angle. I’m gonna have to get extended cables. I found an eBay retailer that will make custom brake lines. Now I just need to find clutch and throttle cables that aren’t outrageous expensive.
I found someone that’ll make a brake cable for me, but I’m having issues finding clutch and throttle cables. If it were a Harley I could get them with skulls and flames all over them. lol I found some on JPCycles, but wondered if I could find them for less than $400i got galfer brake cables they make whatever length you need
