1 - 9 of 9 Posts
All else working but these whether on lo or hi beam. fuses good, checked for intermittent connections within the headlight shell, fuses.
How do I access the service manual to trace down the issue?
Make sure all ground wires are seated tightly. Just one could make them not work correctly.
Also, are the bulbs good?
Ride Smart! Ride Often!
Doubtful both lamps would open simultaneously, but will check. Want the manual anyway. Thanx for heads up
Reactions: Scrumdown
Fixed easy enough. Resold lead to switch in left housing.
That's great it turned out to be an easy fix, those are the best kind.
I had issues with the spot lights on my Silverado S. I had trouble with the wire at the switch on the spot light and made repairs to that. The vibration from the engine was causing the wire on the H3 bulb to break right at the bulb where the wire leaves the bulb. I replaced a few bulbs that looked good but would not work. I resorted to putting a blob of RTV silicone in that area of the bulb to better support the wire. I didn't have any more trouble after doing that.
1 - 9 of 9 Posts
