1 - 10 of 10 Posts
Hello All,
I've been helping my neighbor with his 2008? Yamaha V-Star 1300.
Spring is here and his bike wouldn't start with a dead battery. So we went to replace the battery, only to find it wouldn't start anymore. Crank but no start and leak gas out the exhaust.
I started with the plugs. Plugs were wet. I cleaned them up and tested them against the head. Nice bright blue spark. Test again, no start, fuel pouring out the exhaust. Over-fueling problem...
Cylinder #1 (front cylinder), seemed to have WAY more fuel in it than the rear cylinder.
So I figured it was a stuck injector as he didn't put any fuel stabilizer in it in the fall.
I pulled the tank off and pulled out the injectors. Gave them a proper cleaning (powered up and ran carb cleaner through them), they weren't clogged at all.
Re-assembled it all.
Decided to pull the fuel injection fuse and try to run it to clear the flooding problem.
It cleared the cylinders and fired up for a bit, so I know it's a fuel problem not a spark problem.
I removed the EJK (electronic jet kit) fuel controller to be 100% sure (the bike previously hand a set of straight pipes).
Still not working.
I tried disconnecting the air temperature sensor (under the headlight), gave code 22 and the O2 sensor, no code.
Still not running.
I even tried slamming the fuel injection fuse in while the engine was running while clearing the cylinders. The engine would die immediately once the fuel injection system was connected.
I'm left with the TPS (throttle position sensor) and ECT (engine coolant sensor) to check. These could trick the engine into thinking the throttle is wide-open (when it's idling) or the engine is super cold and the air super dense (it's 12c out, no cold, not warm).
Has anyone run into a problem like this?
Any suggestions?
Thanks,
Stuwy123
2008 Vstar1300
I would suggest checking the wiring to the tps and check values for it .. also if it's fueling like its full throttle could be bad spark plugs.. weak spark and carbon build up or stale fuel will not allow spark as the plug is fouled and grounding out .
make sure something didnt crawl into the air filter and die, or make a nest in there
if the air intake is blocked the engine will flood all the time
Reactions: Mrdub
I've pulled the air filter, no issues. Replaced it anyways.
I figured the TPS was toast because I ohm-ed the pins on the sensor (not plugged in). Turns out it needs to be plugged in.
Still the problem persists.
It appears to be cylinder one (front cylinder) that is over-fueling. So the injectors work mechanically (tested off the bike, good pattern and will open/shut) but are receiving a signal to fuel constantly.
I figured out how to get into diagnostic mode. The fuel pump was firing up constantly while cycling through the menu which I thought was weird. The engine flooded itself while scrolling through the diagnostic menu. Cleared a bunch of codes 12, 15, 46 (can't remember them all). Pulled the fuel pump fuse to clear the flooding. Called it quits for the night.
Any thoughts?
2008 Vstar1300
Any thoughts?
Any thoughts?
I would change not just clean up the plugs for sure. Common failure issue.
Ran the diagnostic test D36 and D37 (injector 1 and 2 tests), no clicks, just fuel pump running. I checked with a mechanic's stethoscope, no clicking. I metered the injectors plugs 12v on one side, grounded on the other. The fuel injectors are wide open, all the time.
Every second the fuel pump is running, the fuel injectors are open, flooding the engine.
This points to the ECU. Which is another question, where is the ECU located? I'm guessing behind the T20 Security Torx cover on the clutch side.
Thoughts?
2008 Vstar1300
Ecu is beside the battery on the left. Not behind the cover but yes that side.
With your electrical test did you notice a pulse on the injectors on the negative side?? With the connector connected to the injector or just disconnected. The pulse is very minute. If the plugs were disconnected you wouldn't see a pulse. But it does sound like your going in ther right direction.
Check to see if the bike ever had the recall work done on it. Mint didn't and dumped fuel twice. Found out the recall work needed to be done. Did this yesterday and yes, huge reason why the 1300s dump fuel.
2008 Vstar1300
What recall are you referring too Jenn72 ?? I haven't seen any for the 2008 1300's.
1 - 10 of 10 Posts
