Not that I want to put the saddlebags to the test - just curious how waterproof they are. Do they keep the water out if caught in the rain?
They are pretty damn good mine have been out in the rain for hours and only a small amount in them not enough to worry about just when you get home take things out if it does get moist
Sent from my SM-J320P using Tapatalk
if they hold up their construction they should. there are a number of universal dry bags on the market to check out. most seem to employ a combination of pvc material with seamless welding and an enclosure that uses a folded/rolled over technique to keep water out of the opening. are you specifically asking about the OEM hard bags for this bike?
Mine will seep through the lock on the top but that's cause the o-ring went catywompus on me once putting it back together
