So, I picked up a 1300 factory windshield and mounting hardware on fleabay for a killer price... I started to install the windshield mounts when I realized I have a small issue. I'm not sure how to remove 2 bolts that are used to hold the mounts. There is no hex, slot or any other visible way of removal of the bolts. Are these pressed in, or am I missing something???
Discussion Starter #2
I figured it out! The previous owner put plastic caps in the holes....feeling kinda dumb now.
looks like an aftermarket trim kit, Ive seen chrome ones pressed into the allen heads for adjusting the handlebars
I wasnt sure from the photo, also looks like JB weld epoxy smeared in there...
It was a press in with no bolts. And yes, they were glued in.
So apparently when I installed the windshield, I pulled a wire loose for my right turn signal. Fixed the ground wire, got running light working again, but no signal. Got test light out, attempted to see if there was power at signal wire, and blew running light fuse. Now the signal is working again, but obviously running lights are not working again. Does this sound like the ground I fixed may still be messed up?
How do you like riding with your windshield?. Only reason I ask is because my 650 came with an aftermarket ws. I have been seriously considering a factory windshield. Before I do that I want to know if the juice is worth the squeeze, any noticeable improvements in riding at higher speeds, 60 - 65MPH?.
