1 - 9 of 9 Posts
I've parted out a 2000 V-Star due to engine problems.
All parts are in great shape. I'm located in Tampa, FL but I can ship anywhere in the US.
Here's a list of what I've got, let me know if you're interested.
-Air Box
-Battery Box
-Master cylinder, lever, and mirror
-Clutch cover
-Clutch hub basket
-Clutch lever with mirror
-Clutch nut, washer, and bearing
-Clutch plates
-Clutch pressure plates
-Exhaust (not sure if I can ship)
-Final Drive
-Front and passenger seats
-Front end (forks, triple tree, axle)
-Petcock
-Risers
-Handlebars
-Kickstand (with the bracket)
-Left side frame cover
-Oil filter cover
-Oil pump
-Fender struts
-Frame neck covers
-Master cylinder cover
-Rear cam cover
-Rear wheel
-Rear axle
-Regulator/Rectifier
-Right side cover (chrome)
-Sissy bar
-Speedometer (13,000) miles
-Speedometer chrome cover
-Starter gear
-Starter motor
-Tool tray
-Turn signals
-Vacuum pump
-Wire harness
I've also got all these parts on eBay if you want to see pics. Just send me a private message.
What about the clutch lever perch? That's the part that clamps to the bars. Don't need the mirror or lever though
Sent from my SM-G930V using Tapatalk
Old thread but...
Anything left? Forks? I live in St. Aug could come peruse
-Air Box
-Battery Box
-Clutch cover
-Clutch hub basket
-Clutch plates
-Final Drive
-Petcock
-Risers
-Handlebars
-Oil filter cover
-Oil pump
-Fender struts
-Frame neck covers
-Rear cam cover
-Rear wheel
-Rear axle
-Sissy bar
-Starter gear
-Starter motor
-Tool tray
-Turn signals
-Vacuum pump
-Wire harness
No Carb??
1 - 9 of 9 Posts
