Really hoping someone can help me. I bought a 2001 vstar classic 1100 with 6,000 miles. It has no issues starting up or idling or revving High while in neutral. As soon as it is put into gear and given any kind of gas it bogs down terribly it's a real struggle to get it over 35 miles an hour the carburetor has been pulled and cleaned twice the valves have been checked and adjusted the intake gasket was replaced all done by a motorcycle shop new throttle cables new plugs still same result idles great sounds good will not rev in gear bogs down could use some help.
Welcome from Houston, Texas. Sounds like jets are clogged. There are small holes in the side of pilot jets that must be clear.
Also check fuel and air filter and replace if questional. If this is you first 1100 here's a must read.
https://sites.google.com/site/vstar1100kb/home/new-owner-must-do-list
Here's a few interesting threads to check out when you get a chance.
https://www.starbikeforums.com/forums/7-starbikeforums-bike-month/
https://www.starbikeforums.com/forums/49-v-star/5655-yammy-ya-got.html?highlight=Yammy
https://www.starbikeforums.com/forums/36-lounge/110258-where-you.html
https://www.starbikeforums.com/forums/11-general-bike-talk/25113-how-experienced-you.html
https://www.starbikeforums.com/forums/36-lounge/113714-how-mature-you.html
Ride often and safe.
I would replace the fuel filter, check the flow coming out of the fuel pump
and check your air filter. You might have a mouse living in your air intake box - engine needs fuel and air to run.
If the air filter is not white like paper replace it. You will be surprised how badly these little air filters will choke off the engine when they are dirty.
If you dont want to pull the carbs apart again, run a pint of Seafoam thru the bike 4 ounces per full tank of gas. As long as the engine will run at all, the seafoam will flow thru the carbs and wash gunk and goo out.
Also have to ask the obvious question: is there old brown gas still in the gas tank? If the gas is not clear drain it out. If you dont know how to get rid of old gas, just put it in an oil drain pan outside somewhere about a gallon at a time, and it will evaporate in a few days.
EDIT:
there is one other possible cause: the bike has a throttle position sensor (TPS) that tells the ECU how much to advance the spark. If its not connected or not giving the right position signal, the ignition timing will be off - it might idle ok then die under load, or the other way around, depending on what the sensor is telling the ECU. Something to check. Its a simple resistive potentiometer on the butterfly shaft on the carb, you can check it with a volt meter.
If you dont have the factory service manual for the 650, you can google it online - free in pdf format. That will tell you how to check the TPS.
