21 - 23 of 23 Posts
Any automotive store will carry spark tester, easy to verify spark.
91919
BTW, for compression tests, its a good habit to run a compression test when you change your spark plugs
you have the plugs out anyway, it only takes a few minutes
and then you have a running record in your maintenance log of what is normal for your bike
then if the bike is running rough, and you check the compression, you will know if it has changed
Discussion Starter #23
Thank you for all your responses, when I posted last the Wi-Fi service went out the next day so I have been waiting to read these post, thank you again, so tommorro I will find out some details. Then post it
21 - 23 of 23 Posts
