Hey guys I have a 2008 roadliner and it has developed an oil leak at the back of the engine. It seems to be gear oil as it is clearer than engine oil and my gear oil level drops slightly but I cannot figure out where it’s leaking from . Any help would be appreciated
Leaks area are normally around gaskets & nuts. Make sure all your nuts & bolts are tighten to spec.
Sometimes cracks in "housing unit". (Hopefully this is not the case.)
I'd look as best you can around the former and see if there are loose nuts.
Ride smart! Ride often!
