Being that I just got this bike recently I never realized that the while the front turn signal units are also are parking lights, the rear turn signal units are only turn signals. Unlike the fronts they have single filament bulbs. Is this factory correct?
It surprises me that Yamaha would only use combo units on the front ones. From a safety standpoint it would have made sense to have combo units on both front and rear. Unless there is some way to retrofit the rear units to work with dual filament bulbs I plan to replace the rears with some sort of combination unit.
Thanks,
Adam
Thanks,
Adam
Yes, both my '95 Virago (basically the same bike) and my '03 650 v-star both have three-wire front signals and two-wire rear signals. They are factory correct. The tail light serves as your rear parking light on the 250. Consider yourself lucky with the set up on the 250. My 650 does not even have a "parking light" key position. There's no (stock) way that I know of to run parking lights (only) on it.
The single-filament rear signals are cheap ($15 for the set of two stock lights on ebay), but you may have to get more expensive OEM front indicators if you really want to go two-filament amber on your rears. I wouldn't bother. I've always felt confident even when I only had the single tailight for the rear parking light. Plus, you may have to wire the two-filament amber indicators so that they're on when you ride, to be able to have them on with the key in the parking position. I just personally wouldn't want that. I've got hard bags on the 250 with built-in running/brake lights and I've mounted a nice running/brake light in the middle of the sissy bar plate. They're all red.
I've also added eight extra led running and brake lights, including patterned strobe plate brake lights, to the back of the 650, and, again, they're all red.
They were all extremely inexpensive and with the added chrome bezels they look fantastic.
Combining always-on red and amber in the rear is not standard or expected. Not only could it cause confusion, it just looks like crap.
I just checked on my 04 vstar 1100 and its the same way. Running lights in the front but not on the back.
If you are concerned about safety I would suggest checking out a break light modulator and some silver star bulbs as they are brighter. The modulator blink the rear light quickly before going solid. Seems to get peoples attention a bit better and makes your more visible. That's just my two cents :)
