So in changing out my clutch lever to the Clevver I had to change the perch. In doing so, the screw that holds the interlock switch on the perch broke off in the stock perch. The problem is, I cannot seem to find another stock perch online. You can see from the pic the only numbers I can find on what I assume was the stock OEM perch. The part numbers for the perch that I find online are 82911 - which is nowhere on the one that came off the bike. Anybody have any insight into this at all? I am trying to go back stock, but I will need this part to do so. Thank you!
