1 - 10 of 10 Posts
I am having trouble figuring out which exact model I have based on these options in the owners manual:
XVS65ATY
XVS65ATYC
XVS65AY
XVS65AYC
XVS65Y
XVS65YC
Here are some pics of the frame sticker. Can anyone help me figure out which model I have? Thank you.
Discussion Starter #2
BTW, for a few of you this will look like a second post. My first one mysteriously disappeared as some others have as well.
the model number should be part of the VIN number on the steering head.
if the rear fender ends right behind the passenger seat, with the turn signals poking thru the fender, it is a Custom
if the rear fender goes all the way down behind the axle , with the turn signals sticking out of the brake light assembly, its a Classic.
The Silverado is a Classic with windshield and saddle bags.
<= mine is a classic (garage photo) click on small photo on garage page to see full size image
the sticker with the engine info is the same for all three versions.
Those pics are your engine info and they all use the same engine. The 650 and 1100 VStars come as a Classic or a Custom model. If you post a pic of your bike it's easy to tell which one it is.
I know that it is a custom, but that still doesn't positively identify it as one of the models in the manual. There are some adjustments and tolerances that are specific to the model. I'm afraid there's more to it than just custom or classic.
there is a link in this thread to look up your VIN number
its right behind the headlight bucket on your steering head part of the frame
If it has a C its a california bike, those are the only bikes with different specs and engine / emission parts.
edit - tried to use that link and it is no longer a valid website - sorry...
https://www.starbikeforums.com/forums/49-v-star/9342-how-tell-silverado-custom-classic-v-star-650-a.html
Unfortunately that link is no longer working. It looks like there's more to it than just the CA special cases. For instance, in the manual it says that the clutch free-play adjustment is 5.0-10.0mm for XVS65ATY, XVS65ATYC, XVS65AY, AND XVS65AYC but 10.0-15.0mm for XVS65Y AND XVS65YC. There are some other places where the specific model matters - tire size and pressure, brake pedal adjustment, max load, etc. For the most part it looks like the XVS65ATY, XVS65ATYC, XVS65AY, AND XVS65AYC are the same and the XVS65Y AND XVS65YC are the same, but which group does my bike fall into? I have nothing that links it to any of those Yamaha model numbers. It's kind of frustrating that Yamaha didn't put the stinking model number on the bike somewhere. Is one of these groups CA and the other all of the rest? Thank you!
the owners manual that is free online says the Custom is XVS650,
the classic is XVS650A
and they stick a C in for california-only bikes.
The tires are different sizes, you can read the tire size off the tires on the bike
I agree its a stupid model numbering system, I have seen the numbers you listed in other places
and the names themselves "Classic" and "Custom" are stupid. What is custom about a fully stock motorcycle right from the factory?
when you modify your Custom Vstar, do you now have a custom Custom Vstar?!
If I write "GENIUS" on my forehead does that make me a genius?!
the clutch freeplay is subjective for the rider. As long as you have some freeplay you can tweak it to get the friction zone to kick in where you want it, nearly all the way out, in the middle, or close to the grips.
The friction zone is very narrow on these bikes.
The brake pedal adjustments are different because the custom has foot pegs and the classic has foot pads - but again, tweak it were you want it.
as for the tire pressure and max loading, get the tire size off your tires, look in the table and see which alphabit soup they call your bike, and you should be able to figure it out. I think the tire pressures are also on the VIN sticker on the steering head.
BTW if you dont have the owners manual or service manual, they really are available free online - google V star 650 Service Manual.
No one can remember those XVS... numbers. When you goto a website to buy parts or tires.. it will ask you make, model (650 classic or custom) year... thats all you need to know.
Hey I appreciate all of the info! The manual I have is the one I downloaded. So I hear you on the custom vs. classic, but I guess there's no way to know what's what with regard to all of those model numbers in the manual.
If I write "GENIUS" on my forehead does that make me a genius?.
KCW, go for a genius tattoo on the forehead and we will monitor your posts to see if it worked. 😇 Here's an example.
1 - 10 of 10 Posts
