ok..it's a strat 2010 deluxe...
was looking at tank removal instuction on both the service manual and the linerwiki site...
can't for the life of me understand where these rubber fule line caps are located......
any thoughts?
or any ideas on an easier way to remove tank..
ps. way to go 24 in Atlanta today !!!
papa d
easy...just take the seat off, look at the base of the tank, see the two nickle/quarter sized caps with a smaller round stub on them...pull em off and viola behind them are the shutoff valves...screw them in with a flathead to shut them off.
Then you have to do the dauntless task of pulling them fuel lines off with those horribible squeeze clamps.....what a bitch to get them back on....oh and by the way you WILL need to remove that left side cover to do all this, the one with the seat removal key latch. you can leave it all attatched (linkage) just get a nice soft towel to wrap it in and just let it hang.
After you have done this twice you too will be a pro... I can get my tank off and plugs changed in about 30 minutes!
great ......i found the caps easy enough..
now why do they not supply the special tool to take the side cover off?
just a security Torx bit......Harbor Freight has them real cheap.....in a set.
