· Registered
Reaction score
0
I’ve discovered this cruise control does not play well with others!!! :eek:
To the point – it kills the turn signal auto cancel function which also uses the speed sensor pulse as a counter. In my case I have a garage door opener circuit installed that lets me activate my garage door opener with two quick break light hits. Well guess what – the relay required to make the cruise control compatible with LED tail light also keeps my activator circuit from resetting. I got around that problem by adding yet another relay. I’m still dreaming and scheming ways to restore full turn signal operation. Until I do that is a problem I can live with…
Knowing what I do now would I still put the 250-1223 on my STRAT?? YUP -- There's no doubt it's a good addition to have...
· Registered
Reaction score
0
Hey Rush, check out this throttle locker. I just ordered one a couple days ago. It won't lock your throttle so much, as you couldn't roll the throttle forward in an emergency stop. It's just suppose to hold the throttle grip so you don't have to.
Here's the link:
http://www.rlmotorcycles.com/cgi-bi...hrottleMeister_Yamaha&cart_id=1264634657.3174
Select the one under "Throttlemeister" logo. It will redirect to options page.
· Registered
Reaction score
0
Discussion Starter · #3 ·
Thanks DINGER...
I already have a very good throttle lock on but got tired of messing with it while going up and down hills so decided to install a no kidding cruise control...
Still working on the turn signal issue. I think I've got a fix figured out but haven't gotten the will power up to start playing with the wires again as yet...
