650 Custom lowering kit spring removal
2344 Views 6 Replies 3 Participants Last post by  Fulltilt1
Dear all,
I just purchased a lowering kit for my 650 Custom from Pacific Coast Star. I wasn't sure, but I was expecting that the installation was going to call for removing the spring. Does anyone know if there is any way to go about this installation without purchasing the spring compression tool (i.e. are there any other spring compression tools that could work, is it possible to easily make one, etc.)?
Thank You,
bsteinma
I have in the past used a ratcheting strap.....Not the safest thing to do, nor the smartest....go buy the tool, or rent one , borrow one from a NAPA dealer...well worth the money
That's what I was curious about. I wasn't sure if I'd need the spring removal tool made specifically for the motorcycle from BARON here http://www.baronscustom.com/catalog/display/571/index.html or if one from an auto parts store would work.
I have used the strut spring compressor tools and I think they will be a little large. You could probably make one with some threaded rod and angle iron. Three short pieces of angle drilled to form a triangle for each end. I'd use barrel nuts for extra strength.
I was curious if that Macpherson Strut Removal tool would be too large because its hard to tell from a picture and if it's not too large it would come very close. I'm not totally sure what you mean by cutting the angle iron into triangles for the end. One of these will definitely be easy to make but I might have to break down and just buy the 55 dollar tool (that is probably composed of only 10 dollars in hardware).
I was just looking at the tool and basically the hole placement is a triangle. Three short pieces of angle with a hole at each end. Six holes line em up and make a triangle, put your threaded rod through it. Well it was good in thought but at $55 I'd probably buy the tool. You'll probably spend $30 to make it, not counting your time.
Diameter of a Strut tool 6 or 8 inches in diameter. I was just looking at the tool and basically the hole placement is a triangle. Three short pieces of angle with a hole at each end. Six holes line em up and make a triangle, put your threaded rod through it. Well it was good in thought but at $55 I'd probably buy the tool. You'll probably spend $30 to make it, not counting your time.
