1 - 19 of 19 Posts
I have a 98 vstar 650 I'm tryin to get a new exhaust and I'm wonderin which one I should get I want loud and more horsepower CAN ANYONE HELP ME OUT?!? And once I get it do I have to rejet my bike? Plz help me out thanx
exhaust
From what I read you will not need to re-jet if all you change is the exhaust. I don't think you will gain a lot of horsepower from just the exhaust. I hear reports of gain in HP if you replace air intake and exhaust, plus re-jet.
Try going to youtube.com, type in V star 650 and search. There will be several video's with sound with several exhausts. Keep in mind the record level is automatic on most recorders so volume is hard to judge. Sound quality is also poor.
Exhaust
Just a word, take it or leave it. If you change exhaust to something like straight pipes for the noise without rejeting you are going to run super hot, you seen the blue pipes? Be careful, if you care.
Discussion Starter · #4 · (Edited)
Thank u both for ur inputs and sugar bear how would I wanna rejet bigger or smaller? And I am gettin a Better air intake also I'm new to the whole redoin pipes and air intakes so if u guys got any tips I would appicate it alot and sugar bear where u from in IN I'm on the border of IL and IN
I am no expert by any stretch, I can turn a wrench and keep my stuff goin. I am saying what the boys in the shop have told me, and what I have seen. They tell me bigger jets the more open you go, what size? depends they say.
jets
If you increase air flow with an exhaust and/or air filter change then the bike may run lean. So more fuel would be needed. Larger jets. Some have periodicly checked plugs for sign of running rich or lean. White plugs to lean, carbon to rich. I have heard several people say that with only muffle they did not rejet. No guarantee on that.
The big air kit comes with instructions and jets. Search the Internet you will see several. Here is one.
http://www.ehow.com/how_4709403_rejet-yamaha-star.html
For rejetting I would suggest going to Maxair instead of Dynojet. Maxair runs just a little bit leaner which means you retain most of your gas mileage. Dynojet makes the engine run very rich (ie. poor gas mileage). For what it is worth. I have had both kits on my 1100 and prefer the Maxair kit. I would also suggest removing or at least blocking off the AIS system. I could also cause the pipes to turn blue.
Hope this helps
Doug
I'm running the maxair with Roadburner Street Pro pipes with the AIS, haven't had any problems at all, also I running a Hypercharger...when I had it disabled I had more problems with it popping on decel: so then I enabled it again and haven't heard a pop yet!
With the Maxair kit you should be fine, Install the exhaust and intake that you'll be using and rejet with the Maxair kit....should do the trick.
Discussion Starter · #13 ·
So I have choice my pipes, air intake, and new jets now my only question is wat should I set my jet size too? I'm usin Vance and Hines cruiser exhaust and maxair air intake and jets so plz some send me something helpful thanx
Good to hear that! You got a killer deal on those pipes, glad you could use them....I was tired of moving them around my garage
1 - 19 of 19 Posts
