1 - 10 of 10 Posts
Hi there my starter motor has decided it doesn't want to work anymore I'm struggling to get a new one, I was just wondering if one would work from a different bike from the star range?
It's a 09 plate
Avail yourself of partzilla.com, a good resource for such things.
For an 09 XVS95 Partzilla says:
This Yamaha 5S7-81890-10-00 MOTOR ASSY fits the following models and components:
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYCR STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYS STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYR STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYB STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYCS STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YB STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YL STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YCL STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YCR STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YCB STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 TOURER - XVS95CTYCB STARTING MOTOR
Yamaha Motorcycle 2009 V STAR 950 - XVS95YR STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 1300 TOURER - XVS13CTZB Starter
Yamaha Motorcycle 2010 V STAR 1300 TOURER - XVS13CTZCL Starter
Yamaha Motorcycle 2010 V STAR 1300 TOURER - XVS13CTZL Starter
Yamaha Motorcycle 2010 V STAR 1300 TOURER - XVS13CTZCB Starter
Yamaha Motorcycle 2010 V STAR 950 TOURER - XVS95CTZCB STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 TOURER - XVS95CTZCG STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZB STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZCB STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZCR STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZW STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZR STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 TOURER - XVS95CTZB STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 - XVS95ZCW STARTING MOTOR
Yamaha Motorcycle 2010 V STAR 950 TOURER - XVS95CTZG STARTING MOTOR
Yamaha Motorcycle 2011 STRYKER - XVS13CACO Starter
Yamaha Motorcycle 2011 STRYKER - XVS13CAL Starter
Yamaha Motorcycle 2011 STRYKER - XVS13CAO Starter
Yamaha Motorcycle 2011 STRYKER - XVS13CACB Starter
Yamaha Motorcycle 2011 STRYKER - XVS13CAB Starter
Yamaha Motorcycle 2011 STRYKER - XVS13CACL Starter
Yamaha Motorcycle 2011 V STAR 1300 - XVS13AACB Starter
Yamaha Motorcycle 2011 V STAR 1300 TOURER - XVS13CTACR Starter
Yamaha Motorcycle 2011 V STAR 1300 TOURER - XVS13CTAR Starter
Yamaha Motorcycle 2011 V STAR 1300 - XVS13AAB Starter
Yamaha Motorcycle 2011 V STAR 950 TOURER - XVS95CTACR STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 TOURER - XVS95CTACB STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 - XVS95AB STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 - XVS95AL STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 - XVS95ACB STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 - XVS95ACL STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 TOURER - XVS95CTAR STARTING MOTOR
Yamaha Motorcycle 2011 V STAR 950 TOURER - XVS95CTAB STARTING MOTOR
Yamaha Motorcycle 2012 STRYKER - XVS13CBCB Starter
Yamaha Motorcycle 2012 V STAR 1300 TOURER - XVS13CTBG Starter
Yamaha Motorcycle 2012 STRYKER - XVS13CBR Starter
Yamaha Motorcycle 2012 STRYKER - XVS13CBO Starter
Yamaha Motorcycle 2012 STRYKER - XVS13CBCR Starter
Yamaha Motorcycle 2012 STRYKER - XVS13CBB Starter
is that where it stops? should be compatible for bikes after 2012 as well.
Yep. And that's a darn good reason to do one's own research. Look at partzilla, search on forums, etc.
As it happens, Partzilla shows the same part # used on 2013+ XVS95 as well, but does NOT list them in the compatibility list. Sort of funny to pull up the starter for a 2014 950 and have the compatibility list only show 2009-2012... Glitch? Bad Data? System limitation? ???
... As it happens, Partzilla shows the same part # used on 2013+ XVS95 as well, but does NOT list them in the compatibility list. Sort of funny to pull up the starter for a 2014 950 and have the compatibility list only show 2009-2012... Glitch? Bad Data? System limitation? ???
Time to hire a new developer or DBA or invest in a QA analyst?
1 - 10 of 10 Posts
