1 - 19 of 19 Posts
I have a raider that I'm wondering about winter storage this coming year. I'm hearing from different people about buying a lift to get tires off the concrete in a un-heated garage. Also wanting some recommendations for a battery maintainer for winter use. In past years I never on other bikes, I never had a lift or a battery maintainer of any kind. I used to just start once or twice a week or just take for a short ride If weather was decent.
Any recommendations would be appreciated.
Thanks, Mak
If you plan to ride it (not just start it, but actually ride it) at least once a month, no winter preparation is needed. The only caveat is if you have parasitic electrical draw, such as engine computers, clocks, radio with preset memories, or the like. In that case whatever you do during regular riding season is adequate.
The practice of starting the engine for a few minutes every week or so "to charge the battery" is, in my opinion, worse than useless. When you start the engine, water created by burning fuel condenses in the cold cylinder and exhaust, and does not evaporate until the engine, oil, and exhaust pipes reach normal operating temperatures. That won't happen unless you actually run the engine under load (riding the bike) for several miles. Ever notice the water dribbling from auto exhausts on a cold day? Ever wonder why exhausts seem to rust from the inside out? It is caused by the normal water of combustion condensing in cold pipes.
If you worry about tires sitting on cold floors, just inflate them to a few pounds above normal (not to exceed the sidewall pressures). If you happen to think about it, move the bike a foot or so every so often to change the contact point.
Try to fuel with non-ethanol gas (not possible for many of us) and use a fuel stabilizer. Put the stabilizer into the tank when you fuel, and the drive home will usually get it into the carburetor or injectors. If the bike is carbureted, and it has a fairly easily accessible carb drain, it won't hurt to drain the gas from the carb. Try to ride the bike at least a few miles (I usually want at least ten miles) before you park it, and if you can't ride it that far don't even start it.
Your owner's manual will undoubtedly have procedures for storage. If in doubt, follow them and at the very least your warranty should remain intact.
On those bikes I actually store for winter, I remove the batteries for convenience. Every month or two, when I happen to think about it, I use an automatic battery charger on them until it says they are charged. Except for my '09 250 Star, all my bikes are '07 models and all the batteries are original equipment and still going strong. Take it for what it is worth.
Blasphemy? Perhaps. It could also be called "Advance Planning." The first day of Fall is less than two weeks away. Of course winter preparation is completely optional. Many folks don't even bother. To see the consequences, go to a public boat ramp on Memorial Day and watch the people who didn't winterize their outboards when they parked the boat just after Labor Day.
Winter storage
LOL..Blasphemy indeed! But you are right to start "planning" for winter ;)...I guess it depends on where you live. If in a moderate climate, where you can bundle up and ride for a while (even a short time to heat your bike up to normal operating temp, then do it. If you are talking snow up the wazzoo for several months and riding is impossible then here is what I would considering doing...one man's opinion and what I do...When I lived in a wazzoo area of Montana and bike was in garage from October till May or June (before the snow and ice melted) I made sure fuel tank was FULL of fuel with a stabilizer (I use "Startron" as it counter effects the ethynol in the fuel) - reason? when not full, the tank will get condensation where there is no fuel every time the temperature changes significantly (happens all winter long) and that condensation will grow into water at the bottom of your tank...I have seen it and worked on ATVs, Motorcycles, snowmobiles, boats that weren't properly stored for their off season. Then when you start your riding season, put on some ISOHEAT (red container, NOT the yellow one) in your first few tanks, to absorb any water that did accumulate.
As far as your tires go, I wouldn't worry about them if they are on DRY concrete...if on a dirt floor, I would stick a piece of 1/4" plywood under them and move them to a different touch point occasionally.Moisture is the enemy of rubber and keeping dry is the key. Same thing I told guys with snowmobiles - if inside on a dry concrete floor - no worries. If outside in the grass or dirt - put a pallet under the track (whole sled preferably) and it's good to go.
Battery Maintenance ---I use a Deltran Battery Tender on all my bikes...easy to install and use. The big enemy of the battery is extreme cold. Charge the battery to full and you can either leave it on and trickle charge or disconnect and reconnect to charge it to full capacity occasionally. I would keep in connected and trickle charging during periods of extreme cold (below freezing temp). If you don't have a GELL battery, GET ONE! They are more expensive than the liquid filled but are a superior battery with less maintenance, last longer and less susceptible to freezing and other problems.
Like it was mentioned above, if you do feel the need to start it occasionally, it doesn't hurt as long as you get the engine and pipes up to normal operating temperature...again, you don't want moisture to set in after you run it for only a short time and not get a chance to burn off the moisture...short starts and stops don't really charge the battery to full because you have used quite a bit of juice to start it...so connect the battery tender back up to achieve full charge.
Hope this helps!
Exactly!
Just doing a little pre-planning for what I might need to properly park it for the lousy Chicago weather coming up. I just thought I would get some tips on battery maintainers and possibly an inexpensive but good quality lift to get it off the ground for the season. Apparently, no one has any suggestions or recommendations so far. When you spend good money on a nice bike, you want to treat it right.
Mak
Thanks dlonewolf588,
Appreciate your response! I was checking out some of the battery maintainers on line the other day. Was just looking for some referrals I guess. I was also thinking of the lift but read some bad reviews on some about being flimsy. Thought it might be handy to have for working on it also. I might have to wait on that though. Money is a little tight. I figured I would check for recommendations on those just for my own knowledge.
Thanks again all, Mak
Bike lift
Hey mak...if you're looking for a bike lift, Harbor Freight has a 1000 lbs bike lift that works just fine...a buddy of mine has it...he did make a change to the wheel chock tho...he took off the one that came with it and put one the wheel chock - also from harbor freight - motorcycle stand/wheel chock item # 97841. The wheel chock is adjustable for different tire sizes. He removed the front support bar of the chock and bolted it to the stand in place of the stock one on lift....works great and locks the bike in well for doing maintenance when raised...you can just lower the lift and leave the bike on it and move the whole thing around...he bought both on sale and it was around $500...I use it when I need it but thinking hard about buying that set up for myself. Hope that helps you.
I have to agree with Charon on all points.
Lucky for me I ride all year or better said able to get out on warm days during the winter.
I would never start any vehicle to Charge the battery at any time unless I knew ahead of time I was going to run that vehicle up to full operating temperature for a few miles.
Moving the bike a foot or two is good for the tires.
I never used a tender on anything (and its been gulp, decades now) in all my boats, bike, cars I ever owned.
I want to STRESS I am not knocking anyone who uses a tender! I just prefer to use my batteries and replace them, its what I think best that works for me.
Boats I disconnect the battery and let sit. Bike I use every couple weeks in winter so I leave it alone connected.
I never treated batteries special, never used a trickle charger, I DO change out batteries every 4 to 5 years no matter what. Boats more like every 3 full years, batteries so cheap, its just cheap insurance.
I have an 08 1300 tourer and just changed out the battery a week ago, replaced it with the OEM Yuasa for the heck of it, been in the bike 5 years already never gave me a problem, now I know I can go another 5 years without a problem but in reality I cant imagine having the same bike for another 5 years, I think another year or two would set a record for me!
Exactly!
I just thought I would get some tips on battery maintainers ...
Mak
Even though I never used one, I do know about electricity and batteries.
If you do use a tender get the lowest power tender you can. Try to avoid "charger tenders" that put out more then 1 or 1.5 amps on the tender side. The reason for this is heat (from charging etc) is far worse for a battery then cold. Batteries hate heat.
A low amp charger such as below I can't see as being bad and will not keep the battery to warm, also keeping in mind the small batteries our bikes have.
Just my thoughts for what its worth.
http://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1/178-2508045-1984060?ie=UTF8&qid=1378822913&sr=8-1&keywords=motorcycle+battery+tenders
Discussion Starter #13
responses on winter storage
Thanks so much everyone for the winter tips. That's what's nice about these forums, getting educated experienced input. What better source?
Thanks again, Mak
^^^ I have 3 of those, 2 jetski and one boat. Jetski batteries are M/C size and these work great.
Normally when it comes to name brands I am not that loyal BUT if a name brand premium product like Yuasa serves me right, even at a little to moderate price premium which is once every few years purchase, I will stand by that name brand product and continue to use it as long as I feel it is still the same high quality product and hasnt has been corrupted and cheapened for the sake of profit like is common with a lot of products now a days.
Do those of you that store your bike in a garage cover it? Put mine in a heated garage Monday (got snow last night and today) and left it uncovered for now. It will be in there at least until April. Never covered my old bike but want to make sure this one stays looking good.
*shakes head sadly*
Guys... simple solution. Move somewhere there is a year round riding season! :D
*shakes head sadly*
Show-off!!
I rode the 1100 today for the first time since getting the Strat build finished. I wanted to work some fuel treatment through the bike. It was 45 degrees and a bit chilly ...
San Fran is starting to sound pretty nice.....
Even though I ride during warmer winter days 60 degrees plus, sometimes the bike sits for a couple weeks at a time when it's colder. I cover it, mainly to keep the dust off it and to protect it from any possible mishaps in the garage.
I guess I did forget to answer the actual question.
I store my bikes in a heated garage. I cover them all year for the same reasons Alarmguy noted, just to keep dust off and protect them from mishaps. I also whisper nice words when I pass by to keep their spirits up :D
Back on the serious note though, I don't plan to do much of anything to prep the Strat for winter as it has no carb. I still plan to ride most of the winter when the weather is above freezing and the roads don't have crap all over them. If it looks like it will sit for a while, I will likely try to use up / drain as much fuel as possible just to avoid any fuel separation issues. However, I don't think it will sit long enough for that to happen, and I use Startron fuel treatment year-round (which seemed to help with the 1100 after letting it sit for over a month recently).
Otherwise, I think I'll do an oil change on both bikes, put a little more Startron than usual in the 1100 and ride enough to ensure it is well into the carbs, check tire inflation, and put the tender on both batteries (I do this year round also). However, the Strat does have a new lithium Shorai battery so shouldn't need the battery tender . . .
1 - 19 of 19 Posts
