i am adding 14 in ape hangers and bought all the cables but i can not find a wiring harness for the handle bar switches any ideas where i can get one or do i have to splice all the wires?
You'll typically need to splice. I'm not aware of a wiring harness with extended length wires that would be plug and play. I'd recommend running the wires through the bars anyway which gives it a clean look. I have 16" apes and the splicing is tedious and a bit tricky fishing through the bars, but worth it. Just make sure you stagger the splices. Good luck!
