1 - 20 of 20 Posts
Hello Everyone
Just ordered my Corba FI2000r Closed loop fuel management for my 2010 v star 950T.
Not looking forward to feeding the wires and connecting the wires to the ports judging what others have posted. Sounds like its a real pain to get everything connected with out removing the gas tank.
Also considering the air box mod (drill some holes in the oem box) until I get a full open air one.
Any thing else I should consider. My bike came with the Vance and Hines exhaust already which I love!!
Has anyone else done these two mods and seen performance gains? I am doing this because I ride two up a lot. I am hoping this makes 75 mph cruising with the extra weight less of a strained endeavor for my 950. It just feels like it needs more power to keep happy at those speeds.
Not sure if I am alone.
Appreciate any input from you guys.
Best regards,
Several of us 950 owners have done upgrades. Personally I started off with a Cobra slip on muffler and a k&n air filter with holes drilled in it for better airflow.
I had minimal gains and loved the sound of the Cobra.
I followed that up with when finances allowed, a LA Choppers XXX open air filter kit and a fuel management system from Cobra. The open air filter kit gave me the most significant gains through all the gears. Bone stock when I hit 75mph, it seemed to struggle. After the open air filter kit, I took it out on the interstate riding two up and looked down and hit 85mph without any effort.
My final upgrade was going with true dual exhaust, and boy did I like the sound! I lost a slight amount of torque, but it was worth it for the looks and sound. I also wrapped the exhaust in header wrap to cut down on the heat.
The 950’s come very lean from the factory and they’re assembled in SoCal and have to meet strict EPA guidelines. Once they’re opened up some, they’re quite different. Some people have the ECU flashed with mixed results, and if you go that route, make sure you have all the mods in place. Hope this helps!
Thanks for the tip Keith. After installing the Fi2000r O2 I noticed some minimal gains as you said through out the power curve. I am still trying to find the right pot, so I think that may have something to do with it. I think mine is set for 2.5/5/4. Maybe a little more tuning it could be better. I think per your recommendation I will just end up buying the LA customs Air filter for better performance out of this thing. I will say with the stock Air box and K and N filter, the biggest difference I have seen is how smooth it is at idle and 0 to 10 mph. Feels like the way the bike should have came from the factory. No more jolting when slowly applying the throttle. Who knew Id be more impressed with daily driving ability then WOT performance with this Corba tuner. lol
Some notes on installation to anyone looking to do this. Be careful not to strip the allen screws for the tank. They look very easy to do. I think I stripped one when putting it back on. (leave that for a future problem, its tight for now)
As many mention you can lift the tank, just remember there is a small tab at the bottom end keeping it from tilting fully, make sure you slide the tank slightly to the right so it can come free.
The tabs are a pain to get too but Its not the end of the world difficult, just try and find the green connectors on the intake manifold. (tip; google what the intake manifold looks like before going into the job like I did.)
My system was a closed loop, the o2 sensor could not have been easier to plug in. Just runt the wire down and plug it in and use the clamp for the OEM cord and your done.
There isn't a great place for the FI2000 to stick too with the provided Velcro. It fits well to the right of the battery. It doesn't have the most real estate int the world for putting stuff under the seat. But it does fit fine none the less. My solution was to use a zip tie for the cord right before it goes into the module and tie it to the frame. Keeps it secure and you still have perfect access to tuning.
Over all I think it was about an hour to an hour and a half not including pissing through a tank of gas trying to find what pots work best.
Now comes the decision to buy the LA customs air box or something else.
Hope this helps anyone looking to buy this cobra tuner or installing one.
Please free to chip in the comments what air intake you have or which pots you think I should run.
Best regards,
You are very welcome! I’m glad it’s working for you. Until you get an unrestricted air filter kit, you may want to back your last two pots down just a tad, but you’ll definitely have to experiment some. I run ethanol free fuel exclusively. I’m fortunate that it’s readily available locally. Running premium I’ve found is just money wasted, no difference in performance. Keep us updated when you find an air filter kit, and definitely shop around. I found mine $100 less than everywhere else.
Per both of your recommendations... I have ordered my LA Customs XXX air intake. Looks dead simple to install. Hopefully I can feel a better power difference when it is installed. This tuner was deff made for having an intake because the manual says dont change the first pot from 2.5 yet when I leave it at 2.5, the bike tries to stall it self like its running too rich. Ive tuned down to 2/4/3 and it seems to run a little better. Power delivery still feels minimal. But idol doesn't feel like its trying to stall itself.
Either way , it wont be a problem soon.
Brevo - Im surprised you have your pots so much lower than I had expected for soemone to have with a full exhaust and intake. Can I ask what made you go down on the pots. Was it additional mods?
Still new to this whole pot tuning thing. Ive only used tunes that have been downloadable.
Best,
I’m looking forward to you updating us after you install it and re-adjust the pot settings.
Update: Interesting changes. LA custom intake installed. Could have been easier. Changed the pot settings multiple times but I think I have found the perfect settings.
Pot 1- Manual says 2.5 is best, and I think they are right.
pot 2- (mid range) This was the most difficult to set. I was all over the place. from 2 to 7 and It took me multiple long drives to find what was best. Right now I am pretty happy with 5.5 setting. 6 was a bit blubbery and 5 felt like it lost some power.
I do notice though when I am over 3 pot setting or more that at mid rpms I hear some valve noises coming out of the intake. No tach so Id guess maybe 2800 - 3500 rpms (I can tell the noise is coming from the intake cause I have my head next to it in an open parking lot while driving in 3rd gear) and I dont mean the whooshing noise that big intakes make.
Is this normal for anyone else? Maybe I need a valve adjustment?
Pot 3 - have it at 3 and it seems to work really well. Tried 4 and it seemed blubbery again.
Im hopping this noise is normal. With all of these setting the bike runs extremely well. Figured it if it was a bent valve I would feel irregular performance.
Thanks everyone for the intake suggestion. Looks fantastic on the bike.
Thanks for updating us, glad to hear you have the settings where you want them. The middle one for me was also the most difficult.
Hey Keith
Did you have more mechanical noise not just the air sound coming from the intake when you installed it. Also what middle pot setting did you end up with. today I rode it for getting Lunch and Im thinking now maybe the third pot should be a little higher.. As I said I am all over the place... Im worried if I go too high i will damage the engine..
Hey,
I just just get a more suctioning noise. When I’m at a light, I can hear it inhaling more air. So in answer to your question, I’d have to say yes, but I think it’s a combination of things. My exhaust is fairly loud, so that contributes to more ‘noise’. If I remember correctly, my middle pot is set at 4.5, but as I mentioned, it was the hardest to dial in.
When I went from the cobra slip on, to true duals, I had to reset the middle one.
Brevo - Im surprised you have your pots so much lower than I had expected for someone to have with a full exhaust and intake. Can I ask what made you go down on the pots. Was it additional mods?
i did have my settings somewhere around 2/3/3 for years and just recently moved them down a tad just to see what kind of fuel efficiency it might give me and if i would notice a difference in performance; just testing for fun. i got to my settings in the beginning by starting out the 2nd and 3rd pots at around 7/7 and just kept moving them down a notch after going through a tank until i noticed a decrease in engine response and that's how i set mine. shortly after i installed the unit i went on a cross country trip and routinely kept the speedo needle over 90mph between fuel stops. my fuel light usually came on at or before i hit 100 miles. that trip made me realize i needed to drop the settings down. i had no idea what the 3rd pot really did at the time so i just set it the same as the 2nd pot. i agree the 2nd one is the most difficult because that's where the most variables are when riding and where much of your acceleration happens.
the instructions for the Cobra FMS were posted in another thread which gives more detail about what each pot does:
Discussion Starter #13
I realized my spark plugs haven't been changed since the bike was new by my guess. Making them about 12,000 miles old. Thinking that may be the cause for the noise (maybe spark knock) and less then stellar gains from the fuel controller.
I have also been running the bike with 87 gas (all gas near me has stupid ethanol gas)
Might try putting in 93 octane and see if that make the bike run better in those pot settings.
Will keep everyone updated on how those two go.
On a side note: the Air intake looks fantastic and wasn't hard to install. I will say that it takes up about the same amount of leg room as the stock air box. So if you are getting this to improve leg room, you will not find that with this air intake. I ran the fuel controller with and with out this intake and there is a noticeable sound difference installing this... A lot more snarly ( if that even makes sense) I also have the Vance and Hines slip on. My neighbors will most likely be filing for my eviction.
I will upload a photo from my phone.
Seafoam:
Discussion Starter #20
Update on my progress.
So I put some injector cleaner in and it didnt seem to do much.
Then I got around to changing my spark plugs this weekend. Removed the old ones and they looked a good caramel color.. Good to know this bike isnt running lean anymore.
When checking the gap on the new plugs I tried to see how the old plugs fared.
Yamaha recommends .034 as the largest tolerance of gap on the plug... My old plugs were at .042
Wow....
With the new plugs I noticed that I needed to play around with the pots again.
After some highway driving I think I am finally spot on with my pot settings.
I ended up with 2.5/6/3.5
Highway pulls are no longer lazy. I can easily run the bike up to 100 when it would feel like the bike would explode if I tried it before.
I haven't tried two up with the new mods... I will update this thread once I do.
I feel like the intake and fuel controller was a great addition... but now I feel like I should do the IVans tune and have the most I can get out of this engine..
Anyone have the fuel controller and Ivans tune who could tell me what they think the Ivans tune did for them.. I know the figures from Ivans website, but Im hoping someone can tell me about real world day to day feel. Any recommendations are helpful for getting more performance.
Best regards,
1 - 20 of 20 Posts
