1 - 10 of 10 Posts
Well i just wanted to know if anyone might have .45 acp brass laying around to plug my ais? Or if anyone knows what else i could use to block it off
Do you have a gun or shooting range nearby. They would most likely have plenty in a trash can.
Up here in the Great White North, finding .45 casings is almost impossible so I went another route. I modified the original elbows that the AIS tube mounted to. I cut the straight part off that pressed into the cylinder and used JB Weld to secure a piece of threaded rod that fit snuggly inside it. After it cured I re-inserted the part into the cylinder. After 6000kms all is well.
The closet range is 50+ miles away from where i am..
1 - 10 of 10 Posts
