Sorry if this has been addressed, but I couldn't find anything.
I will be swapping to the RSTD bars for the 1300, but in the mean time is there a way I can just rotate them up a little? What to loosen etc.
Thanks,
Elk
You have to remove the chrome cover that covers the speedo then you will see the bolts to loosen to adjust the bars. There are 2 bolts one on each side to remove chrome cover. It's pretty easy to adjust bars just make sure you tighten them back up enough and then pull up and push down on bars to make sure they do not move.
Tom
Thanks! Hopefully I'll have the funds in a month or so to get the new bars.
