1 - 9 of 9 Posts
Hello!
I've read the KB and many many posts here and every other place with info on our bikes.
Can someone tell me simply, without suggesting the search feature, lol....what size jets to use? PLEASE!
I have an 07 1100, just put Hardkrome long shots on and am trying to jet for my K&N pods DIY.....
As SMRT as I is, Im just reading so many things its confusing me.
Please lend a hand if possible. I need two mains and two pilots...I never thought four parts would baffle me.
Is there a member here that could send me what I need and I pay pal them the money plus some...I may even need this solenoid thing but some say yes, others no...
Blake
I hear ya'....I've honestly read the KB a dozen times unfortunately, I just am slightly retarding my brain on reading the jet info properly!
Thanks for your quick response, today I'll go buy what I need!
Any other comments or suggestions from anyone would be appreciated!
Blake
there is a square chart .look up wheather modified intake, modified pipes,you would be under pods and performance pipes compare the different setups wether slipons to full pipe.......you are going to have to modify your main jet holder and sickmick sells selonoid delete kits for 25.00 altho it is more fun to make your own.
Ive purchased the needed jets....I cant find sickmick though to get the solenoid delete, would I still need a dyna3000 do you think?
Got my jets and pilots... $27...plus $80 for my two pods.
Ill put my savings towards cams...thanks for the help, ill keep any new info posted!
Quick question. I got my 05 1100 used. came with bub exhaust and the carbs have been rejetted. i dont know what jet kit was used though. i want to put a air kit on. so do the needles need to be adjusted after air kit mod is installed?
Probably have to put new ones to be safe....I cant see any number on them to tell what size they are... I think my previous owner had a diff exhaust and put stock back on. Did he re jet, cant tell.
1 - 9 of 9 Posts
