Is there a way to mount one of those bad boy air horns on our 950? Does it go where the lil stock horn is? Seems unlikely but I'd like to have one of these horns if possible to install. Thanks
On the 1100 a friend of mine took his left accent cover in the Vee off and attached his horn right there. There are two fastener locations he used to mount his included steel bar and then mounted his horn to the secured bar. Used the original horn wire to trip the new relay for the horn from a fused battery source. It blasts out the left side but is loud enough to reflect off a car or the guard rail to be heard 360 degrees.
On V-Star 1300 it's just an accent cover. Remove cover mount horn and relay, then wire to stock horn wire and battery. Works great
Ya just dresses up that side hides the carbs. So if you got a chrome one all the better.
See mines fuel injected and have never really looked under the thing on my left. Going to tonight. Lol
