Ive found allot of the different handle bars available, but I am 5'7" tall and need a different set for my 08 1300 tourer. Its a stretch. What do you recommend?
I,m 5.6 found stock bars a (reach) I installed a set of buckhorn bars its made it so I don't have to grab / pull its like fingertip steering. cables etc fit you have to watch as some bars are a bit thicker so grips are hard to install. ps I also put a set of risers on its a 650 classic
You have to reroute the cables unless you go with vstar bars also different grips. There is a wiki page that shows the height width and pullback on several different bars. I am at work so not able to send link.
Get some cheap pvc and hold it up to what feels comfortable and get a friend to measure the distance. Get the stock dimensions and then search for bars that have the extra pull back you want. I am sure the 1300s are 1" as well so you can use any bar from any manufacturer as long as it fits inside the mounts. Also, a cheap set of risers with a 4 or 6 inch pullback may help you with only swapping those out as well.
The 1300 does not have any such thing as a cheap set of risers as the the speedo is part of the bar mounts so they are not able to use normal risers. Everything I have found shows that nobody makes risers for the 1300 except one company and they are not cheap. I can not remember the company that makes them.
I decided on the Baron RSTD bars. For 100 bucks I can sell them if I don't like them. But I'm pretty sure I will. I did the PVC thing and got the measurements. I think they will be great,
