I just finished installing my X-Arc led signals. They are really bright and super tiny. Wiring was easy but I had to hack off the plugs from my oem signals for a clean look. Soldered and heat shrunk the connections to the plug and done. I used the Kuryakyn hinged mounts and painted them black. Just have to buy the rears (gonna do run, stop and turn) also the fast flash fix relay is on its way. These leds were somewhat expensive but I believe worth it so far. Don't have a pic of them on since I forgot the keys in the house. I will see if I can load a vid later.
