Got myself quite the barn find. $400 for a very pretty V Star XV250 with under 1,000 miles. No title. No keys. Damaged only where someone had hammered out the ignition trying to get is started. Had sat for an unknown number of years. Didn't even try to start it. Pulled the tank and did my best to clean it. Pulled the carburetor, disassembled it, and ran it for 30 minutes in my ultrasonic cleaner. (See the image below as to how it looked going in.). Bought a new ignition and put it all back together. It now starts and idles well, with a few hickups that I'm assuming means an uneven air/fuel flow. The PROBLEM is that it bogs and dies with any amount of throttle. My guess is that means a clogged main jet, but since putting it all back together I have pulled the bowl and diaphragm twice, cleaning with spray carb cleaner, trying to clear whatever the problem is. No effect whatsoever. I did put a new fuel pump on, hoping that would do the trick. Nothing changed. With less than 1,000 miles I've got a hard time believing anything has failed. Capable of no small amount of self-hate and loathing, I've gone over it several times sure that I misrouted a vacuum line or something painfully simple. I cannot find it. Guessing this is a simple fix. Logic insists its the main jet, but it is clean and clear.
Your suggestions, please.
