1 - 20 of 21 Posts
Ok guys, and gals, I have read it here many times about changing your brake fluid. I know many of you suggest it every so often. WHY? Its fluid inside a sealed system. Unless you overheat it or damage a component some how I don't see the reason to replace it. Now granted I am more of a "if it ain't broke don't fix it" kind of guy but I do preform regular basic PM, oil and filter as well as plugs and air filters but I have never replaced brake fluid. I know the manual suggests it but car manuals also suggest replacing tranny fluid, and engine coolant periodically. Both of which I have never done. Someone please explain the reasons why I should do it. I for one have never heard of an accident or vehicular problem because "his brake fluid was old and worn out" If it TRULY needs to be done I will do so but to me it's one of those things that once I am done I will be telling myself, "Well that was a waste of time. No purpose at all in what I just did" I will be doing my normal spring service soon so if I am going to do it now would be the time.
Thanks
Primary reason for brake fluid is that it absorbs water. The water dilutes into the alcohol and lowers its boiling point (on hot disk brakes water actually would boil in the calipers).
Water will also cause corrosion in all your internal brake mechanisms.
How does the water get into a sealed system? Thats a good question. On a car the reservoir has a vent to let in air as the level drops. Where does it go if the brakes are not leaking?
A lot of that is subjective, but I can tell you this: if you flush the brake fluid out of your bike after several years it will be dark yellow to almost brown. New brake fluid is nearly clear.
So something is happening to it, and the engineers that designed your bike think it should be flushed out and replaced every few years.
Maybe its not so much the fluid breaking down - maybe its stuff that corrodes off the brake components that need to be flushed out.
Its normally a very easy thing to do, except for the current recent 'Certainly not a rookie...' thread where the poster ran into some strange problem bleeding the fluid thru.
One thing: when you flush your brakes buy a new bottle of brake fluid - apparently just sitting half empty on the shelf in your garage for several years will degrade what is left in the bottle.
Thanks for the input KCW, Yeah I know it discolors over time and like you I have heard it adsorbs moisture. Granted I am not a engineer or scientist but I have always wondered how a sealed system is going to absorb moisture.
The main infiltration point for this is the piston rubber gaskets.
normal limit is 2% to 3% water absorption.
The higher quality fluid, normally absorbs water faster. DOT3 is the lowest, but also has the lowest boiling temp. DOT4 is higher, boiling temp, but absorbs water alittle faster. DOT5.1 is the next step up.
DOT5 is completely different and NOT compatible with other DOT fluids, your system must be flushed completely clean, they really just suggest you replace everything. It doesn't absorb water. This is what HD normally uses, or used to use.
Water gets in the system from the air that is trapped in the reservoir.. even when you have it full there is an air gap..anytime you remove the cap to top it off air gets in..Even simple expansion of the reservoir can allow minute amounts of air in. Though it seems odd to get moisture in this system..it does. Water will make your brakes feel soft or spongy. For the 1 liter you have to buy every couple years it's a cheap maintenance item to do and maintain the braking systems . Unlike a car you only have 2 brake points..and if one fails.. oh oh.
you're not even supposed to use brake fluid from a bottle that's been kept for over a year; the general rule of thumb is to immediately throw away the unused fluid as soon as you're done. just the small amount of air inside the used bottle contains enough moisture to break down the fluid inside.
i can appreciate the "if it ain't broke don't fix it" motto. but this is scheduled maintenance. the idea is to replace things BEFORE they fail so they don't fail later while you're using them or cause damage to vital parts. you change your engine oil, right? why change that but not your transmission fluid? so you replace your brake pads before they wear completely down and fail on you when you're trying to slow down before hitting a busy intersection. replace your brake hoses before they deteriorate to the point they start losing pressure as you're trying to stop before hitting a busy intersection. you replace your brake fluid to keep your brakes working exactly as they are supposed to so you know that every time you intend to stop, your bike complies accordingly.
you can drive an old beater car and fix things as they break or fail with the possible exception of suspension components
Ive know a couple people that have seen wheels rolling past their car, and realized it was theirs
but on a motorcycle your life is on the line - if something fails on a MC that will be you rolling down the highway at 70mph.
You want your MC to be 100% all the time.
Of all the bad things that can happen to a motorcycle, having your front caliper corrode, start to drag, overheat and then seize and lock up the front wheel - I think that may be #1. You are going over the handlebars.
8 ounce bottle of DOT 4 at Walmart: $4.
The breaks feeling spongy is the lest of your issues normally, it just increases your stopping distance.
The real issue is it lowers the boiling point, and when that water boils in the break line, due to using the breaks and building up heat, it will expand and clamp your breaks SOLID on, and you will not be able to unlock your wheel.
https://youtu.be/wkO2QBFWpPM?t=40
great story about wrecking his bike, gear saved his life.
I bought my first full set of gear from a sales guy that hit a deer at 60mph. Was able to walk away. Has all his gear on a rack at the motorcycle shop where he works. Side and face shield on his full face helmet looks like someone was testing an angle grinder on his head.
Although this guy was wearing some proper gear, this is a pretty gnarly vid.
https://youtu.be/iXSvQxiQYOY
cant really tell what he is wearing, helmet and gloves yes
but sneakers and jeans and a hoodie? I cant tell from the videol
Yeah I think your right. I know they make some sort of designer type of bullet bike sneaker shoe but think he has the standard sneakers on.
How do you get water in brake system if its sealed? Condensation?
Found this this on EBC website:
You might also expect that once the brake fluid reservoir cap is screwed on tight there is no chance of water getting into the vehicles brake fluid, but in fact plastic is porous to a small degree and hence the rubber brake lines and plastic reservoir will allow a tiny amount of moisture to pass through it. The fact that glycol fluids gradually degrade in quality over time as water is absorbed is the reason that hydraulic braking systems must be periodically flushed through with new fresh brake fluid in order to maintain good braking performance. On a typical road car, replacing the fluid every 3 years is considered the minimum but the conditions under which the vehicle is driven also play a factor here. It is not uncommon for track cars to replace the fluid every 3-6 months, or racers to replace fluid every single event!
Water in the brake fluid or a low boiling point is undesirable because as the brakes get hot during use, some of the heat is transferred into the brake caliper and thus into the hydraulic fluid. During rigorous braking temperatures can become so high that the brake fluid boils, introducing bubbles of gas into the hydraulics. This is very bad news since the bubbles of gas increases the overall compressibility of the brake fluid leading to a spongey pedal/lever and in extreme cases can lead to complete brake failure. Many track day drivers will recall a hair-raising moment when their brake pedal or lever bottomed out completely after boiling their brake fluid
https://ebcbrakes.com/articles/brake-fluid/
A week ago Friday my son's car started dragging the right front caliper. When he got home from work he sprayed it down with the hose, and it was a giant hissing steaming mess.
Took all week to get around to putting the new caliper on his car, so I'm manning the bleeder valve, and I tell him - pump the brake 1 2 3 and hold (rinse and repeat).
I can hear him pumping the pedal squeak squeak squeak, the caliper does not move at all, and when I open the bleeder about 2" of fluid came out very slowly into the drain tube... Something was not right.
Did this at least ten times. Pedal keeps going to the floor, no pressure building at all. I'm thinking something is wrong with the caliper from AdvanceAuto, or the brake hose to the caliper was cooked and collapsed inside. Air in the master cylinder?
I thought maybe air got into the line for the back wheel on the same circuit, so maybe we need to put the right front wheel back on, let the car down, take the left rear back wheel off and bleed that cylinder !?!?
Then my son said "OH CRAP! I was pumping the clutch pedal!"
So once again: when something seems to be really really wrong and makes no sense at all, you have made a very simple mistake.
4 pump cycles on the brake pedal, bled out 4 ounces of fluid, and its rock solid again.
That's a cool story. There have many times in my life that simular things have happen. Thanks for giving me a chuckle.
Discussion Starter #17
Thanks for all the information guys. Bike is an 06 and I'm sure the fluid has never been changed. I'll add that to my "to do" list.
I'll be change mine out before the not to long. the bike is a 18, almost 19 years old. (10/99 is the date of creation.) I will assume it has be changed at least once. The mechanic said it should be done soon. (I was not about to pay them more money for that easy job). Color wise, he said it looks fine. But, not knowing exactly what &/or when regular maintenance was done. As much as I like going in a forward motion on a bike. I do like to stop and enjoy the view.
One of my racing buddies was out on a practice lap at Road Atlanta early in the morning around the 2003 racing season when a deer crossed his path. Even though it occurred between turns 4 and 5 which are the slow sections of the track he still split the little deer in half. This was before a lot of riders/racers had access to action cams but it was gnarly for sure. He and his bike weren't too bad off and he was able to race his heats... sadly there was no venison barbecue in the pits that eve... poor us. :crying:
1 - 20 of 21 Posts
